Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-21-2009, 10:39 PM
sortasuave sortasuave is offline
Prospect
Default rebuild kit for the rear shocks?
I appear to have a slow air leak in my stock setup. Is there a rebuild kit for air lines?
At this point I just want to fix it and go down the road. I'll look at replacing them with something better when the $$ come available.
The bike is an 07 Street Glide.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-22-2009, 12:31 AM
genedjr's Avatar
genedjr genedjr is offline
2003 Harley Davidson Road King
The lines are simple plastic lines that can be bought at Home Depot. The connectors at the shock and the other fitting are spring loaded compression fittings. If you fool around with them a little you'll see how to release the lines.
Just take a piece of old line and go to Home Depot and get 6 feet or new line.
Easy stuff.
...gene
__________________
2003 Road King Classic
SE Air, Slip-ons, ME880
Andrews EZ Pushrods
Thundermax w/Autotune
Max Power 71.22, Max Torque 80.54 @6000ft elevation (pre-TMax)
Old 09-22-2009, 09:01 AM
cyclonecutting cyclonecutting is offline
Senior Rider
When looking at the connector, you will see a ring that stands away from the body. Push the ring in until it bottoms out and than pull the line out. Often times you can take a straight razor and just trim 1/4" off the line and reinstall. That has worked for me in the past. You reinstall the line the same way, push retainer in and insert line. I have had good luck by spraying windex on the line before install just to lubricate it and get through the oring without damage.
__________________
2009 RG, Vivid Black, ABS, Rush slip-ons, PCV, K&N filter,16" Cee Bailey shield, KW +2 sweeper bars, SERG bag extensions, SERG headlight trim, SG rear facia
Old 09-22-2009, 09:40 AM
stamper5498's Avatar
stamper5498 stamper5498 is offline
Prospect
where can you get the connectors?
__________________
My Best Friend/Wife
2009 Pewter Pearl FLHX
2009 Black Ice/Blue Pearl
2007 Ultra Gone
2007 Heritage Classic Gone
2007 Dyna Gone
Old 09-22-2009, 11:03 AM
Leftcoaster's Avatar
Leftcoaster Leftcoaster is offline
Like cyclonecutting says: put a fresh end on the hoses with a razor blade or even some sharp scissors. At the shock you will find two red rings where the hoses go into the shocks. push the outer red ring into the inner and it will release the hose. Cut the hose off so you remove the groove and push it all the way back in. You will feel some resistance before it hits bottom. The hose material can also be found at almost any auto parts store.
__________________
Just smart enough to know how stupid I am.
Old 09-22-2009, 04:55 PM
Prospect
Thanks for the update guys. I'll give this a shot this weekend...
Old 09-22-2009, 04:58 PM
Prospect
Quote:
Not 100% sure of this, but if the line is available at Home Depot, they likely would have connectors that would work too.
After that, I'd try the dealership. I'm sure they would be a special order...
Actually... One other idea that just popped into my head, I see threads on here all the time for people changing out their suspension. These upgrades usually do not make use of the stock airlines. So I'd be willing to bet you could find someone on the forum that has an old "worn" system where they'd be willing to send you the parts.
Old 09-22-2009, 07:00 PM
Check out a hydraulic hose repair/supplier. If they don't have the quick release units you can use the feral/crush ring set-up like what is used for semi-truck brakes. Should be available at a good auto parts supplier also.
__________________
Old 09-22-2009, 11:38 PM
Prospect
Thanks, i check these places out, in the meantime anyone reading this has some connectors to get rid of, PM me,
Stamp
__________________
My Best Friend/Wife
2007 Ultra Gone
2007 Dyna Gone
Tags
air, davidson, harley, king, kit, kits, oil, rear, rebuild, replacing, road, shock, shocks, showa, softail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
