I am trying to find out if anyone knows of a license plate bracket that will fit the wider rear on the 2010 RKC to relocate under the light. Harley's kit won't work and Kuryakyn does not have one. I have a nicer looking luggage rack, but it won't work with the plate in the air. I zip tied it in place until someone can give me a better solution. I cannot believe that someone on the planet hasn't made one, yet.
Also looking for the Street Glide rear directional lights for the 2010 RKC and wondering whether or not 2009/10 stock takeoffs will work.
The relocation kit from Harley is for the RK standard. The fender tip is different and won't work. There is a light on the tip. Street glide is different and won't work either. I've looked at both.
I saw a RKC with the plate mounted on the rear fender like a mudflap the other day if that helps.
THis is kind of how mine is, if you take the little plastic crome fender tip thing off there are a couple of holes there, two of them where whear the crome tip was hooked on, I bought a bracket from my local mec. that bolted in those holes and the plate to that, then I put a crome licence plate bracket on the plate.
Terry
I am glad I am not the only one that hasn't been able to find a pre-fabricated unit to do this. The billboard mount sucks. I am sure that in time someone will make a nice unit to do what Harley should have done in the first place.
