Yesterday I picked up my new bike,09 EGC,Flame blue pearl/pewter pearl,WOW is an understatement.I loved my 06 standard,but this thing is amazing.I'll get some new pics this weekend.My question is will the HD Security Siren that I had on my 06 work on my 09,and where does it connect to.
I had the turn/brake/module on my rear lights and found out that it doesn't work on the 09.I'll buy the new run/turn/brake module and modify it with instructions from here.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
What are you going to modify on a new run/turn/brake module?
__________________
2009 Vivid Black Ultra Classic
2003 Gunmetal Ultra Classic - Will miss her
1985 Wide Glide - Gone
1983 Sportster - Wish I still had her
I have a 09 also and wanted to have the brake and turn signal brake without the running option, I wrote to badlands and they told me how to do it, just snip the BLUE wire out of the modual it works great ! below is copy of the email he sent me hope this helps you !
Hi Bill,
You can use our ILL-01-A Plug-In Illuminator module to do that. You would
just need to cut and insulate our blue wire to defeat the running light
mode. (Make sure to ONLY cut the wire coming directly out of the module, NOT
the jumper that continues the blue wire to the rear fender plug.) We
generally don't recommend this as having the additional running lights is a
good safety feature, particularly at night. However since your FLHX has the
tri-bar light at the bottom of the fender, you're probably okay. I'd still
prefer to have the extra running lights, but it's up to you!
Also, the ILL-01-A has the Load Equalizer III circuit built-in, so no
problem for the LEDs.
Please let us know if there is anything else we can do to help.
It should work. I had a siren in the garage from my other '05 and it popped right in my '09 and works fine. On the '09, the siren goes behind the left side cover. Remove the left saddlebag and that will allow you to remove the left side cover. Look for a harness and plug at the very bottom of the fuse panel area. That is the siren plug. Right now it is plugged into a blind hole. Remove it and plug into your siren and pop the siren into those 3 tabs you see located in the upper left of the fuse panel area.
