Broken screw on derby cover
Old 08-12-2009, 05:33 PM
HD101st's Avatar
HD101st
HD101st is offline
Default Broken screw on derby cover
How to extract same without damaging clutch assembly its the top screw so there is no leakage issues but i was wondering what to use
Old 08-12-2009, 05:35 PM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
Vise grips if there's enough to grab onto. Easy-out or left handed drill bit, if there isn't.
Old 08-12-2009, 05:37 PM
Clint55's Avatar
Clint55
Clint55 is offline
Lots of solutions. opinions and ideas here.
https://www.hdforums.com/forum/touri...from-hell.html
Old 08-12-2009, 06:36 PM
dawg's Avatar
dawg
dawg is offline
Received 2,955 Likes on 1,711 Posts
If somewhat of a head, dremel a slot and screwdrive it out. Otherwise, drill and ez-out it out.
Old 08-12-2009, 06:47 PM
HD101st's Avatar
HD101st
HD101st is offline
Well 1 issue there is no head its broken off i brought it to the dealer because its only 6 weeks old initaially they told me couple days now thats turned into 3 weeks so i am going to pick it up from them sunday if they dont have it done and get a pro grabit set and try to extract it anybody have sucess with broken off heads?
Old 08-12-2009, 07:11 PM
deucer03's Avatar
deucer03
deucer03 is offline
If Harley has used their famious yellow goo (Loctite),I would try heating it up and using a grab device or vise-grips.A soldering iron works well with a little patience and without any damage.
Old 08-12-2009, 07:17 PM
Bushy's Avatar
Bushy
Bushy is offline
I picked up ez-out at sears for 14 bucks, ez-pz
Old 08-12-2009, 07:25 PM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
You can try a allen. I have had luck doing this. The problem (mostly) is the torx and allen screws they use is very shallow-button head-which can cause the driver to slip because it does not lock well. Their soft too.
In God we Trust
dd
Old 08-12-2009, 07:29 PM
qwest's Avatar
qwest
qwest is offline
Your bike's been at the dealer for 3 weeks waiting on a 10 minute job?
You're a very patient person.
Old 08-12-2009, 09:20 PM
2002jadefatboy's Avatar
2002jadefatboy
2002jadefatboy is offline
Had the same problem...EZ out took it right out.
Quick Reply: Broken screw on derby cover
