Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-09-2009, 10:02 PM
paco ritter's Avatar
paco ritter paco ritter is offline
Prospect
Default Finally, a fix for the 103 starting problem
Yes, they can fix it if you stay with'em long enough. I had this problem for 6 months, dealer tried numerous things. New starter clutch, new stock compensator with extra springs added, worked over the PCIII on the dyno, changed timing, changed fuel, changed anything that might effect the starting. Still sounded like a thrashing machine often when I tried to start it because the starter would kick out and try to re-engage. TERRIBLE. spit back thru the throttle body. turn over and over and never start. I WAS SICK OF IT. Every one said "gotta put compression releases" or "gotta put a heavy duty starter". They finally got hold of a tech at HD that told them to install the new HD SCREAMIN' EAGLE COMPENSATOR and that would fix it....and.....THAT DID IT. I have started and ridden it several times over the past 3 days, not one time did it fail to start right up and do as it should. Once again my faith is restored in HD. The tech that installed it said it had to be built, came in about a dozen parts and pieces, unlike the two or three in the stock version. Much heavier duty and does the trick the stock one could not do. PACO
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Paco Ritter
Old 08-09-2009, 10:43 PM
KoalaCowboy's Avatar
KoalaCowboy KoalaCowboy is offline
2009 Harley-Davidson Ultra-Classic
Paco,
What cams are you running? What Pistons?
Glad you got your issue fixed!
__________________
KoalaCowboy
09 Ultra - 103" Stage III, MoFlow AirCleaner, BUB 7's, Pewter Pearl Inner, Brushed Aluminum Gauges, and much more!
Old 08-09-2009, 10:47 PM
cdestuck cdestuck is offline
Glad your all fixed up. Just too bad that the info was just not a little quicker in coming.
__________________
Dan Stuckey
Altoona, Pa
Old 08-09-2009, 11:06 PM
Prospect
I am running stock heads, 103 jugs, flat top pistons, and SE255 cams. PCIII, Fulsac duels with Rush 2" mufflers, SE stage 1 breather kit. Dynoed at 86hp, 105 torque. Does great, just had a helluva time getting it to start without sounding like it was coming to pieces. SE compensator seems to have fixed that after many other things tried. Was going for SE compression releases next if this didn't fix it, but don't think I'll have to do that now. PACO
__________________
Paco Ritter
Old 08-09-2009, 11:23 PM
meveratt meveratt is offline
Senior Rider
I had the hot starting problem, and one guy suggested starting the bike as soon as you turn on the ignition -- not waiting for the engine light to go out. That has worked 100% for me. I just completed a 6000km trip to Sturgis and back, and the only time it thrashed and banged was the one time I let the engine light go out.
__________________
Mike
2008 Road Glide
SE 103 stage II Kit
Lotsa other stuff...
Old 08-10-2009, 12:06 AM
Wally Wally is online now
What's the part # there buddy?
__________________
06' Road Glide - SE 103", SE Six speed, SE Slip-Ons with Bub True Duals, HD Numbered Paint Set, Street Glide Rear Fender and lots of Shiny Stuff
99' Ultra - SE Intake,D & D Fatcat,Revolution 98",BC Gerlomy Bored Throttlebody,GMR heads, Andrews 37 Cams, Tour Pac Quick- Tach,Sundowner, Hog Tunes, SERT, Sirius 105 tq. 95 hp
Old 08-10-2009, 03:13 AM
EG Ultra Classic EG Ultra Classic is offline
Senior Rider
Send a message via Yahoo to EG Ultra Classic
I'm glad they fixed it for you Paco. My latest starter fix was a new high output HD starter. No warranty as the machine gun sound from the factory starter was only occasional, and naturally wouldn't do it for the service tech. Now, HD has a service buliten out stating the rattling sound is normal, so, no warranty anyway untill it completely quits. I paid the price for a new high torque HD starter. What the hel, they needed a stimulous package. so far so good.
__________________
2008 Ultra Classic FLHTCU Stage II 103 HD kit- SE 255 cams, SERT, stock 96" heads, manual compression releases, SE high torque starter, Capt. Itch crotch cooler, and BUB 7 exhaust. 86 HP, 103 TQ
2008 Triumph Rocket 3-Touring, 2300 cc triple cyl. WOW!
Old 08-10-2009, 07:05 AM
brettnbama's Avatar
brettnbama brettnbama is offline
I am so confused now.....that's three different fixes to the same problem, the new compensator, the high torque starter, and compression releases.....
__________________
09 Vivid Black Road King
09 HD Iron 1200
Old 08-10-2009, 07:30 AM
rapz's Avatar
rapz rapz is offline
I'm having new heads w/ACRs installed as soon as they come in. I'll mention the SE Compensator and see if they have a service bulletin for it so it'll be installed under warranty.
__________________
2008 105th Anniversary Ultra Classic 103" SE Upgrade
2007 Street Bob
Old 08-10-2009, 08:19 AM
vtwinbmx's Avatar
vtwinbmx vtwinbmx is offline
It all points back to your CCP and the duration of the SE255 cams. I have over 20K with my SE251 cams with 195 CCP and NEVER have a starting issue
__________________
07 Big Black Bagger
Tags
clutch, compensator, davidson, duels, fixes, forums, fulsac, harley, ignition, kicks, problem, problems, starter, starting, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
