Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-06-2009, 10:33 PM
StreetGlider56's Avatar
StreetGlider56 StreetGlider56 is online now
Default noise in primary
Posted this in trans/primary forum but it's a ghost town... maybe get som resopnse here
I have noticed a whirring noise in the primary lately, I have about 13,500 miles in the clock.
Has anyone had to replace the shoe for the hydraulic adjuster in the primary?
Is it true you can use ATF in the primary?
Will it shift harsher?
Going too pull it apart this weekend but would like some input from an experienced member who has been there...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-07-2009, 08:08 AM
heavymetalthunder heavymetalthunder is offline
Senior Rider
2002 Harley-Davidson Heritage Springer
My Garage
my 08 has the whirling sound also. Dealer says its nomal. I've heard other bikes make the same noise. time will tell. I hope its not a bad omen of problems to come.
__________________
2008 Road Glide
2002 Springer
Old 08-07-2009, 08:10 AM
backdoc_rider backdoc_rider is offline
Senior Rider
My bike makes all kinds of noises. They all seem "normal" to me. I did find that switching to ATF in my primary made it smoother shifting. The clutch engagement smoothed out (although I still need an adjustment in there I think). Overall I'm happy with the way the ATF is working, but it didn't seem any quieter in there.
__________________
http://i5.photobucket.com/albums/y171/chiro972/phpGaGlaOPM.jpg
2008 FLHTCU
Old 08-07-2009, 08:35 AM
kman780 kman780 is offline
Prospect
Its probably normal but I had that noise after my 103 build and my primary nut was backed off. Cleaned it up and road it ever since and no noise at all. I got a case of the HD Synth 3 oil from someone so I run that in my primary and can't hear any noise over top end ticking....
__________________
2006 Road King
103 CI FI
VH True Dual
Old 08-07-2009, 08:50 AM
Shank Shank is offline
Prospect
well, it seems like im there now too..mine is an 07 ultra got 32,000 on it and i never did hear a "whiring" sound in mine although after asking around i hear it normal, they changed the adjuster to different type in 07..but what i have is the occasional "rocks in a can" sound...what i have been told is that it might need to be reset...also the techs i had talked to said to get on it a little bit ( yeah i do baby it ) and it might just come up one more click and stop my noise otherwise pull the primary and check it out...i know thats a diffefent issue that you are having,,,but the whirr seems to be normal....
__________________
The only thing bad about riding is when you have stop!
Old 08-07-2009, 06:12 PM
Default whurring...
Well I know there should be some noise from the "combine" type setup but
I also noticed the oil pressure dropping when hot (and it's been hot here in Texas) but I also had another weird thing happen, as i approach the last 5 miles of the 17mile ride home from work I looked down and noticed the neutral light on Will going down the road in 4th, and 5th, and 6th
when i stopped at a light to turn into the sub division the light still on,
I look down to see if a wire popped of (this is when I heard the noise a whirring noise that i thought wasn't normal) the light stayed on all the way home, shut it off, waited for the bike to cool off and fired it up and lo more light, and the "more than normal noise is less noticeable but still there.
what do you think, tear it down? inspect?
Old 08-07-2009, 08:53 PM
Prospect
ya know,,oddly enough my neutral light did that a few times when it was new ,,but hasnt done it since ,,,,kinda just thought that maybe the ground wasnt making at the switch ,,im thinking its just the threads and they do have sealing compund on them ...i dunno about tearing it down or not but if nothings wrong all ya got in it is a gasket.......i guess if there is you ought to see it right off,,,,maybe ask a few techs first...everyone i talked to said they whine,,,me i never did it hear it...
__________________
Old 08-07-2009, 09:32 PM
JustLoafin JustLoafin is offline
Prospect
Is the noise going on all the time when the engine is running? Does it come and go with the clutch engaging or disengaging? Have you found anything that makes it better or worse?
__________________
'07 Ultra Cobalt/Pewter Pearl
SE A/C
V & H Basic Slip-ons
Thundermax &
True-Trak!!
WA Plate LOAFIN
Old 08-07-2009, 10:05 PM
I'm going to diagnos it a bit farther tomorrow, thing I remember it changing rythym when clutch engaged and released...
Old 08-08-2009, 12:13 AM
Prospect
If you hear the noise when the clutch is out and go away when the clutch is in and tranny in gear, good chance its the inner primary bearing/race. Try different combos of clutch in/out, in gear, in neutral, moving, not moving and see if you find some common ground when the noise is made. Report your findings and see if we can help!!
__________________
SE A/C
Thundermax &
True-Trak!!
WA Plate LOAFIN
Tags
4027408, clunking, clutch, coming, disengaged, glide, harley, hd, making, noise, o8, primary, sound, sportster, street, whirring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
