Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-19-2009, 01:57 PM
emwolb emwolb is offline
have you tried anything like a fuel injection system cleaner in your fuel? i use chevron techron plus in my fuel every few months, and it keeps the system clean as a whistle. i discovered this stuff (available at walmart) in the corvette forums, as my fuel gauge would cease functioning sometimes. it was the sulphur in the fuel coating the sending unit in the tanks. yes, it has two saddle tanks, a pain. but the fuel we have available to us ain't the greatest, and the techron plus cleans the system out. just a little bit though, not a whole bottle by any means. there are spray cleaners also which you could use for clearing out the iac and throttle body. just make sure it won't harm anything in the process. be sure you mask around everything else, you don't know what it'll do to painted surfaces.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Jim Barnhart
Old 08-19-2009, 02:02 PM
sorry dude. my harley doesn't have saddle tanks, nor did i have troubles with the fuel sending unit. those issues were for my late model corvette. thought i better clear that up. but there are many types of safe throttle body cleaners out there, as well as fuel system cleaners too. i stumbled across the techron plus, and found it to be very suitable for my harley too. one bottle will treat 12 gallons, so about a third would do ya probably. it doesn't harm anything. be sure to use a funnel when installing, as i'm not sure as to how it would react to paint. i hope this is useful information for you.
__________________
Jim Barnhart
Old 08-19-2009, 02:09 PM
Ribitt Ribitt is offline
Prospect
Cool
Have you changed the plugs. my 07 UC did it and it was the tips of the plugs were comming loose sending a code to the puter and making it die slowing down and then idle at about 500 after restarting. All only happened when it was hot. Had to go back to harley plugs till I can find some that the tip is permenatly attached.
___________________________
07UC, Rinehart TD's, SERT, SE A/C
S&S Geardrive, Andrews 26 Cam
Old 08-19-2009, 03:05 PM
pled55's Avatar
pled55 pled55 is offline
Quote:
Originally Posted by cryan9 View Post
My bike has stalled three times in about a month. The first time I was coming to a stop at a light and it idled low and died. Black smoke shot out of the Heavy Breather when it died. It did the same thing again about two weeks later. Yesterday I was driving at about 45 mph and down shifted to 4th gear because the car in front of me slowed down. When I gave it gas it didn't respond because it died again. On all three times it started right back up with no check engine light coming on. It has been dyno tuned with the pipes and breather that I have. It is not due for a service for another thousand miles. The only thing that I can think of is that I went from the High Flow Stage I to the Heavy Breather. I am running the High Flow Stage I breather bolts with the Heavy Breather that I put on myself. I found out later that I need to use stock breather bolts. Could this be the issue. I ran the breather since November this way and didn't have any problems until now. Does anyone know what else it could be? It seems to be some kind of air or fuel problem I would think due to the bike starting right back up.
not sure i understood that you did use your stock air cleaner bolts .but with the heavy breather you are supposed to use the stock ones .there was a post here a while back that had the same problem as you .and the bolts was the problem.hope this is helps
__________________
09 flhx
red hot sunglo
abs,cruise,
chrome front end /lowered
chrome controls/switches/stealth grips
sundowner for the long haul
pc-v reinhart slip-ons,heavy breather
Old 08-19-2009, 03:22 PM
cybricon's Avatar
cybricon cybricon is offline
Hang Around
Default Mine was due to loose sensor wires
My '07 Ultra was occasionally stalling, idling high, and difficult to start when hot. It took awhile to find the problem - my local dealer didn't find it but on a road trip another one did. It was loose sensor wires that sit up between the heads. They give power to the O2 sensor system, so since they were loose, the onboard computer was not getting the information. The mechanic said the wires are a little too tight so they can pull off easily. He spliced on some extra wire to give it more slack. Runs fine now.
__________________
2007 FLHTCU
Old 08-21-2009, 08:30 AM
wild1s2 wild1s2 is offline
Hang Around
I have changed plugs,plug wires,air filter,cleaned IAC, and have ran injector cleaner in the gas. Just not sure what to do,still thinking it's a bad IAC. It had stalled out a couple of times before I shot the carb cleaner it to flush it out,now it just drops to a slow idle when this happens.
Old 08-21-2009, 09:22 AM
kpb46's Avatar
kpb46 kpb46 is offline
Senior Rider
My 07 Ultra does the same thing. Sert, SE air cleaner and Rienhart slip on. Been to two different dealers several times...no help. When it starts acting up if I just stop for a short break (coffee, beer etc.) it clears up. Has happened several times 33,000 on the clock and it started early on. Just got a call from a friend who has a 07 SG. His has started doing it. You would think Harley could figure this out. It is dangerous. Had mine quit at very low speed while downshifting to make a turn. Leave ya hanging out there in the intersection with no power.
Had to go thru the frame cracking and overheating problems with my Goldwing..now this
Old 08-22-2009, 09:29 AM
Hang Around
My 06 SG started out with a slow idle and the stall when coming to a stop. I flushed out the IAC opening and it helped with the stalling but it still will idle down to around 600 rpm. There is no there is no method to the madness either, it'll be fine one day and then the next day do the same thing for 5-7 stops and then clear up again.
Old 08-22-2009, 09:49 AM
Scooter68's Avatar
Scooter68 Scooter68 is offline
2004 Harley Ultra Classic
Send a message via AIM to Scooter68 Send a message via Yahoo to Scooter68
Quote:
Originally Posted by TNTHarley View Post
I'd bet it is the PC III. Bounce this one off Jamie at Fuel Moto and see what he thinks.
My thoughts exactly.
__________________
Scott J. Koehn 2004 Ultra Classic, Vance and Hines True Duals, Rinehart Slipons, Arlen ness Big sucker Stage 1 A/C, Vance and Hines Fuel Pak, 279 total lights, and lots of chrome.
Old 08-26-2009, 03:25 PM
motman motman is offline
Hang Around
Replace the AIC mine did the same thing. dealer couldnt or wouldnt fix it ordered and replaced it my self...
__________________
07 dyna low
Tags
2007, classic, cleaning, davidson, fuel, harley, harleys, iac, idle, king, road, sender, stalling, stallng, stop, techron, ultra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
