i'm gonna go with this i-a-c-m idle air controll motor . what makes me say that, well when it stopps working alltogher you'll be calling for a tow at 3 am have your indy or dealer run a digignostic on it ... ( me spelling sucks)
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
My love is in league with the freeway
Its passion will ride as the cities fly by
And the tail-lights dissolve in the coming of night
Thanks guys for all of the input. I will try and see what's going on. It is more frustrating than anything. I just don't want to be doing any damage to the motor. I checked my plugs a few months ago and they were okay, unless they just went bad all of the sudden. Where is this IAC motor located?
__________________ 2009 Night Train, PCV, Short Shots with Thunder Monster Baffles, Tri-Bar L.E.D. Light, spray painted lowers and handlebars. Lowered 2" rear end.
It is on top center of the throttle body, just behind the breather. It is the round black cylinder looking device. Idle air enters in the small hole in the top of the throttle body, the amount of air is controlled by the idle air control motor. It is basically like a valve, opening and closing to control the amount of air entering the engine through the small hole in the throttle body while at idle. At least, that is my understanding.
I have an 08 Street Glide and it has done this too me 5 times. First three was right after I put the PC 3 on and thought that it might be runing lean so I took it up a little at idle. Did good for about a month then did it two more times, always fires right back up like nothing wrong. I was thinking bad gas or plugs changed them now just waiting for it too do it again. I am hopeing not . Will be keeping an I here to find out what other people say. My bike only has 3500 miles on it. And leaving for Texas on Friday from KCMO.
I had this happen on my bike. I read on another forum that it could be the PC III. So I took the side cover off, unplugged it from the ECM and plugged it back in. Then reset to original map then reinstalled the new map. I have not had a problem since. I think my PC III may not have been plugged in all the way or plugged in properly or maybe it was not making a good connection. Whatever it was I have not had the problem since re-seating the plug and reinstalling the map.
__________________
God Bless America - 2007 Road King Vivid Black
K&N Air Filter, PCIII, Rush Mufflers, Quadzilla Hoppe Fairing, 440 Progressive 11.5 Heavy Duty Shocks, King Tour Pack, Elite III's
Merritt Island Florida
I had the stalling problem on my '07 Street Glide also. I tried using fuel injection cleaner in the tank numerous times. I sprayed carb cleaner in the IAC port also to no avail. I had no codes showing up. The dealer said try plugs. I could not believe plugs would cause intrmittent stalling so I bought the IAC motor. When I watched the old one cycle with the ignition it was not as fast as the new one and when I removed the old one, it was gummed up. The new cleaners don't remove the deposits like the old ones because they are environmentally friendly. Anyway, took the bike for a ride and so far so good.
I put too much oil in mine and it started doing this...removed some oil and cleaned the oil from the IAC etc and hasnt stalled since...probably 6 months ago...
Did ya replace the IAC? Was it gunked up, ports clogged, potentially blocking airflow? Did replacing it help? Thinking about doing same, just curious.
Ez
__________________
Life's short and only a oneway ride, live it!!
2007 FLHRC
Can someone tell me if you have to pull the throttle body off like it tells you to do in the repair manual? Or can you lift the tank and remove the IAC? I keep getting the low idle problem off and on and would like to fix this problem.
I had this on my 01, it was breaks in the wires in the wiring harness, that follows the frame, in front of the gas tank, before the steering knuckle. When the bike is idling, squeeze the wires, and if the bike stalls, cut apart the wrap, and fix the wires. Caused by the fairing hitting the wires when the bikes steering was all the way to the right too many times.
I did the same computer, diagnostic checks, and couldn't find anything, and an old school wrench squeezes the harness, and finds the problem after three seperate new age wrenchs looked at the bike and couldn't find anything wrong.
