Anyone install an oil temp gauge in place of the air temp? I have the bike tore down to the frame, but I can't figure out which plug to pull out of the bottom to install the temp sensor. Then did you run the wire right up the frame underneath the gas tank?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
Have you see Fireman Joes site and this for your bike... I have one and I feel like I have 343 Souls riding with me... actually it's 346 - they added three retired FF's who were working at the Towers when they came down...
__________________
Enjoy today for tomorrow may never come,,
Harley
History is a myth that men agree to believe.
Napoleon
Don't use any thread tape, pipe dope or loctite. It is a tapered pipe thread and it will seal very well. You will need good metal to metal contact for a good ground.If you don't already have the adapter to mate the sensor unit to the oil pan, it is a 3/8 NPT(M) x 1/8 NPT(F) or Napa # 3220 x 6 x 2. It is a brass fitting. I ran my wires piggy back along the clutch cable.
Quote:
Originally Posted by harley0711
Dirty but it shows the connection {Hey I ride my bike - its NO show queen. lol}
VERY IMPORTANT **************************
This is a STEEL fitting going into an ALUM case - Be VERY CAREFUL
Rumor has it that the adapter is now being included in the HD kit with the new part number superseded with an "A" on the end. Apparently HD now admits that the previously prescribed method is flawed and installing the sender in the pan is the best option.
__________________ 2007 Street Ultra
Stage 1½: Fuel Moto Power Package, SE255 cams.
Just installed one myself. Question though ... I was going to use the (inner) oil pan plug as illustrated in the photos above, but my dealer service manager said not to because that plug leads to an oil pan chamber that "has no oil in it". So I used an adapter to fit the probe into the oil drain plug (outer) hole. Obviously, when I drain oil, I have to remove the probe to do it. I have a feeling I got some bad info! I assume the inner plug works fine for all of you? Thanks.
