Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 05-22-2009, 11:30 AM
1999E-Glide's Avatar
1999E-Glide 1999E-Glide is online now
Prospect
Default High Speed Front End Wobble
First of all let me say I have never had my bike above 85 MPH untill last night. I don't ride fast I don't feel safe. Last night I was on a LONG (3 mile) straight stretch 2 lane each way and I decided to open it up. Everything was fine till I hit 100 then the front end started wobbling back and forth about an inch each way. I immediately slowed down and at around 80 everything smoothed right back out. The front tire is a new Dunlop Elite 3, just had fork oil changed and was running 10 lbs of air in front forks. Front neck bearings just greased and checked. The front and rear seem to be aligned perfectly so I am clueless. Anyone have any ideas? I was not in a curve at all so not the inherent "frame flex".
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
1999 Electra Glide Police
Vivid Black
Andrews 26G Cams
S&S Gear Drive
Old 05-22-2009, 12:16 PM
only90s only90s is offline
Hang Around
I had the same issue last Fall and discovered my front tire pressure was low...that was all.
__________________
2009 Street Glide-Jackpot Dyno Tuned Mufflers, PCV, Big Sucker
90 Mustang 5.0-540 Supercharged Horsepower and as fun as the SG
2006 Street Glide-sold, 2002 Deuce-gone but not forgotten
Old 05-22-2009, 12:46 PM
cadman311's Avatar
cadman311 cadman311 is offline
Send a message via Yahoo to cadman311
Batwing thing
__________________
07 FXDL LOWRIDER Pearl Red
04 ROAD GLIDE, Red
http://www.myspace.com/cadman311
Old 05-22-2009, 12:54 PM
HarleyGoodies's Avatar
HarleyGoodies HarleyGoodies is offline
Premium Sponsor
Tire pressure, batwing, steering head tightness...What size wheel and tire on the front end?
__________________
60 DAY MONEY-BACK GUARANTEE - FREE PRIORITY SAME DAY SHIPPING
EXTENDED PROMOTION - GET A FREE SKULL BANDANNA WITH EVERY ITEM ORDERED
Old 05-22-2009, 01:05 PM
BC Glide BC Glide is offline
Prospect
Might not be a front end issue. I have an 08 street glide that would scare me over 80 mph I have installed a bagger brace and cleared it up on the straight stretches also cleaned up the ride on grooved pavement.
__________________
2008 Vivid Black Street Glide
1998 Fat Boy "sold"
Old 05-22-2009, 01:17 PM
gmc's Avatar
gmc gmc is offline
Are you running an E-3 on the back also. You may be getting some tire pattern difference problem if you have a worn 402 on the back. Tire pressure on both?
__________________
07 FLHTC 103" STAGE II, SERT W RTD, 84 HP 101tq.
92 FLHTC 175K MILES, X BRAND 235K MILES, FIRST BIKE 49 INDIAN, USAF 67-71
Old 05-22-2009, 05:19 PM
Prospect
Running Dunlop Elite 3 on Front-Back was a new D402 when I replaced the front. Running 38 lbs in front and 36 in rear. When I get home I am going to pull the fairing and check where the forks go through the triple trees. I am hoping when I had the front end redone and fork oil changed, something did not get left loose. Any other ideas?
Also they are factory 16" front and rear wheels.
__________________
Vivid Black
Andrews 26G Cams
S&S Gear Drive
Old 05-22-2009, 06:08 PM
Bryan TTM Bryan TTM is offline
bet your swingarm isolators (rubbers between the tranny and frame that the swingarm pivot bolt passes thru) are compromised
Old 05-22-2009, 06:24 PM
hogbag07 hogbag07 is offline
If your bike never wobbled before the new tyre that's your problem check to see if the tyre is on the rim straight did you have it balanced etc. Drop all the air from the tyre and brake the bead put some soapy water in the bead area inflate to 50 psi to make sure the bead seats drop air back to 40 psi . Try this if it does not work replace tyre with new again
Old 05-22-2009, 06:26 PM
imrotton2's Avatar
imrotton2 imrotton2 is offline
Senior Rider
2 yrs ago i had the rear swingarm on my 2000uc break , on the left side , rite where the axel goes thru.. the axel nut and shock was all that was holding it.. it showed up when i was removing rear tire( keep a check on that side of swingarm)JMO
__________________
it's not about what you are , it's about what you become !!!!
Tags
2006, 2009, changing, electra, end, front, gears, glide, harley, high, motorcycle, road, speed, sportsterfront, street, wheel, wobble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
