Ok guys, been a while on this one so here goes. Two BRAND NEW Dunlop Elite 3 front and back. Checked wheel bearings-great shape. Checked front fork fallout-exactly as service manual describes. Torqued Head nut as in book and greased neck bearings. Air pressure exact. On way home last night running about 80 it went into the scariest wobble ever. I let out and it stopped as soon as I rolled the throttle again it started all over. Got off the exit and ran 40 all the way home just fine. Checked EVERYTHING again last night. On the way to work this morning at 70 did it again. Bike has never been wrecked. I also checked wheel alignment and it seems dead on. Here is the kicker-put my wife on the back (140 lbs) and it does not do it. Can run 80 all day long with her back there and no problems. The ONLY thing I can come up with is the rear swingarm bearings are shot. Any ideas? I am going to take it to the indy tomorrow and drop it off. He allready said he doesn't think its the swingarm but there is NOTHING else it could be. Any help is appreciated. I am this close () to trading it. Thanks.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
do you have spoke rims? loose spokes will cause it everytime. thats also one of the things in the service manual your supposed to check regularly. grab the spokes by hand and see if you can move them at all. if you get even a little movement then they are to loose. If you get no movement then take a wrench and tap the spokes one by one. you should hear a fairly high pitched ping with each tap. if you hear a dull thud then the spoke is loose.
__________________
You cant know where your going until you know where you've been
Neck Bearings are New-Greased
Wheels are aluminum-No Spokes
The only thing left is the Swingarm. Here goes the money.
Kevin
Being a mechanic its not unheard of to receive a bad tire that is brand new. In fact i put a brand new Metzler on the rear of mine that i took right off the shelf AND even ordered that tire myself from Drag Specialties a few weeks before and it went bad. the whole sidewall cracked on both sides within a month.
I would have the shop that installed the tire to put a new one on and re-balance it. just my thought since it never did it before the new tire was put on
__________________
Hey E-glide,that's interesting. I just put a set of E3's on my bike. Got up to 85 and got a wobble. Nothing life threatening but it made me slow down. After a few hundred miles it seems to be O.K. now. Doesn't make sense?
Before the E3's I could do 95-100 on the same stretch of road no problem.
Bad batch of tires?? if Firestone can put out a whole line of bad tires then its entirely possible
__________________
I have (had) an '07 SG. I've put just over 20k on it. I just put new Avons and aluminum wheels on it Sept. 10th. A couple of buddies and myself were headed on a little cruise for a coldy on Sept 20th.
I hit a long sweeping 90 degree turn at about 70. As I checked up, I got a bad head shake. I almost made it out of the turn, but ran out of asphalt just as I hit the straight. As soon as I hit the shoulder, which was soft dirt, the handlebars snapped left. I figured I had slowed to about 50 at this point but not sure. Everything went black and I woke up on my back in extreme pain and no air in my lungs. The SG did an Endo, but landed mostly on its left rear side and ended up facing the wrong direction. I was thrown completely over the scoot, landing about 10 feet past it. Judging by the pics, it looks like the bike went about 30 feet after impact. Luckily it didn't land on me. I suffered 2 broken ribs, some minor road rash and a bruised larynx. VERY lucky. Especially considering what I was wearing, which consisted of way too much confidence, tennis shoes, shorts and a cutoff t-shirt. Lesson learned on the riding gear. No clue what caused the wobble. Have been on much tighter turns with no problems. State Farm is still working the numbers. Hopefully it will be totalled so I can get a new one.
Yes, I already know I'm an idiot for my lack of gear, but I'm sure you guys will lecture me anyway. I'm ready.
Here's the pics for your viewing pleasure and confirmation of my stupidity:
