2008 Roadglide, Stereo upgrade/how-to
List of parts (main components):
1. Focal 5.25" components (Polyglass 130vr)
2. Alpine 4.150
3. Hawg-wired Universal hand control module/ radio bezel.cradle kit
4. (4) Pioneer 6x9s (Premier TS-D902P)
5. carpeted/upholstered bags
6. wires/ quick connects, etc.
7. JVC KD-AVX44, head unit
all wires soldered and ran as if they were supposed to be there... still waiting on the 6x9s, but most wires are done, radio is in and hand controls work flawlessly...
2. Alpine 4.150
First thing I did, was prepare myself for the install, organizing tools, product, etc. took the outer fairing off the bike, to see what i was working with.. then using a bench... i prewired the radio, installed it into the hawg wired bezel and cradle and installed it on the bike, process was simple and took literally a couple of minutes...
in this case with the dvd player aspect of the JVC, the parking brake wire can be grounded to allow video playback... also the illumination wire from the radio, is connected to the hawgwired harness to allow, hand controls to dim and brighten the radio...
unplug the maxi-fuse
prep the bike for the install, remove tank, bags, etc... i already knew i needed to run 5 wires back to the back along with the 4ch rca (5 wires are two sets of speaker wire, left and right fairing speakers and remote wire for amp... so i went ahead and ran these wire under the tank with the factory wires and used similar heat shrink to hide the wires going into the fairing...
unplug the radio harness, remove the 4 screws from the factory radio and slide the radio out
slide the new radio in and (using blue locktite) bolt it in place... plug the factory harness into the hawg wired, plug the wired remote plug into the aftermarket radio (and in my case), put the maxi fuse back in place to test the radio...
moving along, unplug the maxi fuse again...
i new exactly where i wanted to put the crossovers for the focals, so i presoldered the speaker wire onto the midbass/range drivers, making them a little longer than needed... (everything on this bike can be returned back to factory and all wires were soldered and ran to look as good as possible, even though the owner will prob never see it, or notice)...
remove the factory speaker (three main torx screws, the whole assembly comes out, then 4 phillip head screws to remove the speaker... i wanted to keep the bike/install as clean as possible, so i mounted the tweeter onto the factory speaker pods...
soldered/heat shrunk the remote wire for the amp to the JVC plugged in the rca-s... next, i worked on the bike's side of the quick disconnect... as i said, need a 5 wire quick disconnect and i found a good weather resistant plug, the 10 gauge and 16 gauge quick connects for power and ground and the 6x9s in the other bag... i soldered all wires and heat shrunk over them... as far as power and ground at a distance of 3 feet, the 10 gauge is more than enough... i thnk it works out to be capable of around 200 amps or something like that, but anyhow, it is sufficient...
I also used a circuit breaker, manual reset...
some soldering, normally get a good bead, heat shrink it, do the other wire, heat shrink that, then heat shrink to two together...lol sound like a lot...
found the place to put the breaker
ran all the wires through some loom and cleaned the area up (zip tie, etc)...
this is what will need to be unplugged, to take the bag off
i didnt quick connect the rca, because i went higher end on the speakers, they will plug right into the amp, and be easy to unplug...
in the 08 Roadglide there is plently of room behind the right cover.. i used this area to house the circuit breaker and ran the wires, so that it would appear as close to stock as possible...
