Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-26-2009, 02:21 PM
nemick's Avatar
nemick nemick is offline
iclick, is it your intention to dyno your bike at some point just to find out the numbers you are making now?
Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Neil M.
'09 Ultra Classic
'08 Cross Bones
'09 Night Rod Special
Old 03-26-2009, 02:28 PM
iclick's Avatar
iclick iclick is offline
Quote:
No, I don't. Not to sound arrogant, but I don't really care what the numbers are, as I know what I can feel in my butt dyno, and the numbers are good!
Besides, I didn't do a dyno before the swap and think that would be important in comparing. Fuel Moto's dyno chart for the stock TC96 with his Power Package was done at 17% humidity, which only exists here in S. LA in our imaginations, and with high humidity the numbers would be lower anyway. So if I compared a dyno run after the swap with Fuel Moto's chart it might not show much improvement, but also wouldn't be a very accurate comparison.
During my research someone sent me a dyno chart for the SE255's on a TC96 equipped with RH TD's. I superimposed the chart for the FM PP (lower curves), which is representative of my original configuration, and I feel this shows a fairly accurate before-after comparison. This is except for the low-end part of the 255 chart, which is lower I think because of the TD's, and it is well-known they hurt low-end TQ. Based on what I can feel I think the low-end is now a bit better than the FM stock chart and the rest of the chart is a fair representation of what I am feeling with my butt dyno. If you assume the low-end is higher than shown for the 255's, what we have is a nice, smooth curve that has essentially moved up 6HP & 6TQ without shifting to the right, and that's what I feel like I accomplished.
__________________
2007 Street Ultra
Stage 1½: Fuel Moto Power Package, SE255 cams.
http://www.iclickphotos.com/Motorcycle/0000-080702-04aLH-Bike.jpg
Link to larger image
Old 04-24-2009, 06:24 AM
RjCapp's Avatar
RjCapp RjCapp is offline
Nice right up.
Thanks
__________________
http://i277.photobucket.com/albums/kk67/renocapp/mann-fuzzbusters-large.gif
Old 04-24-2009, 07:12 AM
rapz's Avatar
rapz rapz is offline
Great write up. Thanks for the info. Need to file your report in my service manual.
__________________
2008 105th Anniversary Ultra Classic 103" SE Upgrade
2007 Street Bob
Old 05-24-2009, 03:03 PM
TheWhitedogg's Avatar
TheWhitedogg TheWhitedogg is offline
Senior Rider
Quote:
Originally Posted by iclick View Post
3. Valve-train noise not higher than stock, which was a surprise. However, the mufflers are a bit louder and that is no surprise. What is weird is the exhaust tone at idle, which has a more single-cylinder sound than before, and that tone holds up to about 1250 RPM's, then smooths out more like normal. Idle is no rougher than stock, however, which is still not anywhere near smooth. This tone isn't bad, just different, and doesn't seem to be related to AFR's. This may be a factor of the mufflers' asymmetrical baffles and the cams combined. At roll-on it makes very pleasing sounds like you would expect.
I just installed my set of 255's yesterday. The project went pretty smooth with only one setback. I used the SE adjustable pushrods and the intake rod has to be adjusted down to the very shortest position to get it in. My fat fingers accidently spun the lock nut off and it fell into the lifter cavity. The entire project took me 7 hours and was a good learning experience.
One thing that concerns me is the valve train noise. Mine is noticably different/louder than before. The exhaust sounds better and has a lope to it that lets you know its not a stocker anymore. I was able to take it out for a short run this am and it performs alot better. Has that snap your head back power I was looking for.
My other concern is the clutch. It has enough torque to slip the clutch in 6th gear. If I jump on the throttle at 60mph it will break the clutch loose and rpm's jump way up and the 6th gear light goes out.
All together I have about 400 into the upgrade, (used cams, adjustable pushrods, cam service kit and inner bearing puller/installer). I'm going to have it put on a dyno this week just to see what the numbers are and if they are way off from what I expect they should be I'll try to get my map altered to make any adjustments.
__________________
07 Road King - under construction
SE 255's,V&H Big Shot Duals
PC-V, 78 HP, 98 Ft Lbs
Healthy dose of black, with a dash of chrome
Old 05-24-2009, 03:30 PM
iclick's Avatar
Quote:
Mine sounds different, not as much of a lope as I've heard on some other bikes, but definitely louder. I installed a smaller right baffle for my Jackpots and it helped, but still louder than before. I did expect this, so it isn't a complaint.
What I don't have is more valve-train noise, and that did surprise me since I expected more. There is an increase but you can still barely hear it, just a faint clicky sound that doesn't bother me. Compared to my old Evo with an Andrews cam this bike is like an electric motor.
Yep. I'm very pleased with the performance result.
I'm not getting any slippage at all. I wonder if you need to adjust your clutch at the basket, or if your clutch disks need replacing. How many miles on your bike? Mine is at about 31k now and you shouldn't be having clutch problems until well past 50k unless you're hard on the clutch. Are you running a synthetic motor oil in the primary? If so, try something like Castrol GTX 20w50 or some other inexpensive fossil engine oil or ATF. If you're using an oil with friction modifiers like moly it can cause clutch slippage.
I came in at $285 but reused the stock pushrods, so we both did very well IMO for the performance increase we've realized. I think the SE255's are a very trick and under-appreciated way to realize a meaningful and practical performance increase in a TC96. I continue to marvel at the response from the engine at any RPM--just twist the wrist. I'd like to see your dyno results when completed. Based on what I had before I would guess at 82-84 HP and near 100 TQ.
You have a PCV so did you change the map yet? If not the cams will change the behavior of the MAP sensor enough to require a map change. A dyno tune will do it, map upgrade from Fuel Moto (if you bought the PCV there), or just buy the AT kit and it'll auto-tune while you ride. For $300 I think the latter is the best option.
__________________
2007 Street Ultra
Old 05-24-2009, 03:57 PM
street_glider's Avatar
street_glider street_glider is online now
2008 Harley-Davidson Street Glide
I'm jealous! I wanna a cam upgrade wwaaaaaaaaaa!!!!!
__________________
2008 Street Glide
96TC, PC-V with Auto Tune, AN/BS & Custom Slip-ons, Hog Tunes
Old 05-24-2009, 04:33 PM
How about a run down on why you chose the 255 over the other offered grinds..
__________________
2008 Street Glide
Old 05-24-2009, 04:54 PM
Senior Rider
My valve train noise is also a "clicky" sound, much more so than stock. Enough so that I may take the pushrods out and reinstall just for piece of mind.
The bike has just under 20k so the clutch disks should be fine. I am going to adjust the clutch and see if that helps. I run amsoil 20-50 maybe I should change. If all else fails, I'll look into the HiPerf clutch spring HD sells with their 103 stage 2 kit.
I did get my PCV from FuelMoto, and had Jamie send me the map for the 255's last week so I would have it on hand. I have the slightest stumble off idle to 1st gear. After I get a pull on the dyno next week, I'll have Jamie fix that and based on the dyno results anything else he might recommend.
Street_glider - I chose the 255's based mostly on reports by Iclick and others on this forum. Great cam for those who want more torque and are not concerned about peak HP. If I am at 82hp and 95tq I'll be very happy. I wanted to improve the cruise range torque for passing. These cams are also readily available used on ebay for cheap. They come stock in the SE 110's and alot of those owners upgrade to 260's or better
__________________
Old 05-24-2009, 05:21 PM
Ah, sounds good to me too!
__________________
2008 Street Glide
Tags
4, afr, andrews, cam, change, chart, considerd, detonation, dyno, harley, hd, lean, tw21, tw66, whats, woods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
