Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-11-2009, 09:57 PM
hover's Avatar
hover hover is offline
Prospect
2007 Suzuki King Quad 700
My Garage
Quote:
Originally Posted by FatBAGstr'd View Post
I was told by a tech that the bike also must have cruise control in order for the cylinder shut down to work? He explained that you had to set the cruise, then negative roll the throttle to shut the cylinder down.
More BS? I have an 09, but no cruise. Be nice in the Texas summer heat to be able to use this feature if I can.
Doubt if you need cruise, but the cruise indicator changes color when activated. I'm sure your bike has the indicator? Also check to see if there is a - idle position on your throttle...its all in your manual.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2009 Ultra Classic
Old 03-11-2009, 09:59 PM
Conehead's Avatar
Conehead Conehead is offline
Senior Rider
I have actually turned mine on while setting at a stop light just to see if it is possible and it worked as advertised. I rolled the throttle forward and the cruise light turned green and it was activated.
__________________
2009 Ultra w/ABS "Vivid Black"
Firefighter Special Edition
"We are still thinking too much in this country about our rights and privileges and not enough about our Duties, Responsibilities, and Opportunities!"
Old 03-11-2009, 10:00 PM
garys_ultra garys_ultra is offline
Hang Around
My 09 has that feature,, you roll the throttle forward and hold it unitll the cruise light blinks orange and it shuts off the rear cylinder, when you roll it back it kicks back in. havent had a real hot day to try it other than playing with it at the stop lights.
Old 03-11-2009, 10:10 PM
09StreetGlider's Avatar
09StreetGlider 09StreetGlider is offline
All 09 touring models have this feature. Roll forward on the throttle and the cruise light will blink after a few seconds. (regardless of if you have cruise control). If it blinks orange, you just turned ETMS off. If it blinks green, you just turned it on.
You have to be at a complete stop with the clutch pulled in to enable/disable ETMS. Or you can do it at idle in neutral while at a complete stop and the clutch does not have to be in. Or you can enable/disable before you start the bike with the ingnition switch to "ignition" and the run/stop switch to "run".
You cannot determine when your engine shuts down the rear cylinder on any model or any year. You can only enable/disable ETMS. The ETMS will shut down the rear cylinder only when certain conditions are met. Engine temp, speed (zero I think), clutch in, throttle at 0%. As soon as you roll back the throttle or let out the clutch in gear the rear cylinder starts again.
__________________
2009 Street Glide
HD Stage 1 103", PCV with AT, Jackpot Dyno Tuned Mufflers,
HD Premium Oil Cooler, Hogtunes, 80 HP/97 TQ
Some people spend an entire lifetime wondering if they made a difference in the world.
But, the Marines don't have that problem.
Ronald Reagan, President of the United States; 1985
Old 03-11-2009, 11:35 PM
keltonkrew's Avatar
keltonkrew keltonkrew is online now
works great on my 09. last October in stop/go traffic sitting forever at red lights it would activate....does sound kinda funny put put put.....
__________________
09 FLHR- Cruise/ABS/ SOOS Extenders Fuelmoto Pkg 2.25" jackpots, Heritage bars Woody's Fairing and Mustang solo
09 Heritage Softail - Wife's Bike - Fuelmoto Pkg 2" Rush
Old 03-12-2009, 12:09 AM
garyhendley's Avatar
garyhendley garyhendley is offline
when did they start adding the parade mode on the tourers my buddy has a 05 rg
and he tells me its happened to him i have never had a heat issue since i changed
to synthetic and i ride to vegas almost once a month-ride safe
__________________
06 Road Glide se stage 1 a/c se mufflers mustang seat custome chrome parts
Arlen Ness Hotshot ton of kuryakyn harley thunder star rims arlen ness / h-d a/c fullsac
true duals AMSOIL DISTRIBUTOR FOR SAN FERNANDO VALLEY
Old 03-12-2009, 10:15 AM
ranman469's Avatar
ranman469 ranman469 is offline
I found that when stuck in trafic i rool the throtle foreward to turn off the rear.
and if the traffic it creaping i hold the throtle foreward and just let out the clutch just a bit to move , and the rear cyl stays off.
it works i was stoped in freeway traffic on a 85deg day for 1/2 hour with no problems
__________________
sport bike is gone! now i can ride all day!!
stage 1 76.4hp 87.87tq with SE pro super tuner
reinhart slipons lovin the ride!!!!!!!!!
113 is next summer
Old 03-12-2009, 09:45 PM
ezriderpgh's Avatar
ezriderpgh ezriderpgh is offline
What he said plus a little more info........when it is activated and shuts down that rear cylinder you will smell fuel and the rpm's will drop to 950 from the normal idle of 1050. The cylinder will kick back in at 1200 rpm's, clutch in or not....so don't blip that throttle. I also would not recommend using it at any time other than heavy traffic because if it is activated and it shuts that rear cylinder down while at a stop, if someone rolls up on you too fast the bike will sputter when trying to get away. Don't ask how I know this.
__________________
'08 FLHTCU Ultra
City Of Champions - Pittsburgh, PA
Old 03-13-2009, 03:52 AM
newdep332's Avatar
newdep332 newdep332 is offline
Prospect
Quote:
Originally Posted by ezriderpgh View Post
What he said plus a little more info........when it is activated and shuts down that rear cylinder you wil smell fuel. The cylinder will kick back in at 1200 rpm's, clutch in or not....so don't blip that throttle. I also would not recommend using it at any time other than heavy traffic because if it is activated and it shuts that rear cylinder down while at a stop, if someone rolls up on you too fast the bike will sputter when trying to get away. Don't ask how I know this.
I have a 09 Heritage and an 09 EGS if either bike is in heat management while sitting still both bikes will immediately engage rear cylinder when you give throttle. No spitting or sputtering instant power!
__________________
2010 FLSTSE Crimson Red Sunglo/Autumn Haze
Old 03-13-2009, 06:40 AM
ezriderpgh's Avatar
Quote:
Then you are rare. Six people in my ride group have it and all have the issue. You may have it engaged but I seriously doubt it is active, it takes alot really for it to activate and shut that cylinder down. Check the rpm's next time, if not 950 you're still running with both.
__________________
'08 FLHTCU Ultra
Tags
09, back, cutout, cylinder, davidson, harley, hd, heat, management, rear, running, shut, shutdown, stopped, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
