I want to install hydraulic clutch kit to my 6 speed ultima and also change my hand controls, can You tell me what master cylinder should i buy 9/16 or 11/16?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
Since the other respondant has no clue....
If you're running dual calipers, 11/16...9/16 for singles.
And yes, you'll notice a difference. They're very sensitive. As soon as you let off the clutch lever a fraction, it grabs and wants to go.
__________________
'06 Street Glide...Branch Heads-JE/Branch 95" Pistons-S&S 585 Gear Drives-Feuling Oil Pump & Cam Plate & Lifters-Jim's Roller Rockers-Delkron Rocker Support Plate-S&S Pushrods-Mikuni 45mm-NOS-Baker DD6-Baker +1 Oil Pan-Pioneer-Polk Audo-Biketronics Amp-Covered in PM Bling...too much stuff to list.
Wanna know what else is on it...PM me!
I'm not asking about brake master cylinder, but about CLUTCH MASTER, there are aslo 9/16 and 11/16 to chose from, which one should i take if i'm instaling the 99-06 harley hydraulic clutch kit? anybody using it? if yes, can You check your left hand control and tell me, what is writen there, usualy the bore is engraved.
Guy?
I went to HD's website to lookup what you need. It mentions nothing about the clutch side coming in different sizes. However, it does mention the brakes and states what I already posted regarding the sizes. I had to look this up because I was a bit baffled. I've installed a few hydraulic clutches and don't recall anything regarding the bore size for the clutch reservoir.
__________________
There are aftermarket hydraulic kits for HD's, although I'd have to look around to see if the one I have, a MAGURA , which is available from Drag Specialties will fit your bike.
I have one on my 03 FLHTPI and it is as sweet as the one on my Jap bike.
If you have a Drag book check it out
__________________
2003 FLHTPI.... keeping the dream alive
2002 Kawi ZRX 1200 R
1985 Kawi GPz 550
In case nobody comes through with the stamped size, most references that I came up with were 11/16" clutch master cylinder bores. It all boils down on what size the slave is for matching. Good luck.
Ron
__________________ 07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Guy?
I know that the HD kit comes in one size, but is it 9/16 or 11/16? I cant find it. I've got HD hydraulic clutch transmission cover and want to buy aftermarket hand master cylinder for it which is offered in two sizez 9/16 and 11/16. So which one will fit?
Are you trying to get them to match up for banjo bolt sizes?
The bore has nothing to do with banjo bolt size.
__________________
