Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-21-2009, 07:39 AM
LT782 LT782 is offline
Hang Around
Quote:
Originally Posted by DuraGlide View Post
Try sliding the brake mount and switch housing up the bar very slightly. Be careful not to go to far or the throttle will drag to much and won't return to idle properly.
Thank you Sir. I'll try that this evening. After mucho thought about the whole deal, I think that makes sense.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-21-2009, 07:47 AM
Notgrownup's Avatar
Notgrownup Notgrownup is offline
I would think the CC and rider backrest was the best MOD i did on my EGC. If i can help it i will never have a bike w/o cruise.
Old 09-21-2009, 08:50 AM
coolmac coolmac is offline
Prospect
Just installed CC on my 10'.
CC worked right out of the box, no download needed from dealer.
If the brake light stays on, make sure the brake Assembly and switch Assembly is
tight against each other.
No pulling pins out for cabling,just adding new prewired pins.
Plug and play.
__________________
Flight 93 We will never forget . . .
Shanksville VFD Memorial Cross, constructed with actual steel supports from Ground Zero.
2010 Road Glide
Old 09-21-2009, 09:45 AM
Hang Around
Plug and play.
Did your 10' RG come with the star wheel under the switch for throttle friction adjustment? If so what did you do to have some friction after the switch housing change?
Thanks
Old 09-21-2009, 09:56 AM
Prospect
No . . .
Saved $100 installing myself vs ordering with the new bike.
Just worked that way . . .
Having CC is like garage door opener, once you have it, its a must have.
__________________
2010 Road Glide
Old 09-21-2009, 06:38 PM
Hang Around
Duh. Came home today and took the rh switches off. Checked the manual for the throttle sensor and grip. The grip had slipped rearward off the splines of the throttle sensor. When I was using the word friction I should have been using the word tension but both kind of apply. Fine now. Thanks for the responses.
Old 09-21-2009, 06:56 PM
Bertk's Avatar
Bertk Bertk is offline
Quote:
Glad to see you figured it out. Just leave a tiny bit end play so the grip twists smoothly, and does not bind.
__________________
Ride Safe, Bert
http://home.comcast.net/~bertkk/Sig2.jpg
2008 FLHX - Black Pearl | 103ci | Baisley SS Heads | Bub 7 Ture Duals | Woods TW6-6 Cams | SE/Zipper A-C | TTS MasterTune | SE Performance Clutch | Chrome ThunderStar Wheels | Khrome Werks +2 Sweeper Bars - Photo Gallery's and Link Page -
Old 09-21-2009, 08:21 PM
Blitz63's Avatar
Blitz63 Blitz63 is offline
Hang Around
Is there a speed limit the CC won't work at...thought I read somewhere you couldn't set it 80 mph or faster...Going to Sturgis next year we are going to roll out west!! Thanks Guys!
Old 09-21-2009, 08:58 PM
Bertk's Avatar
Quote:
The CC functions from around 36 to 86 mph. Above or below that is not considered cruising, so they say.
__________________
Ride Safe, Bert
Old 09-26-2009, 02:28 PM
wtrskinut1 wtrskinut1 is offline
Hang Around
Does the dash switch come with the cruise control?
__________________
2008 SG, Rinehart Tru Duals, SERT, Stage 1
Tags
08, 2008, 2009, control, cruise, davidson, electra, flhx, glide, harley, install, installation, installing, instructions, kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
