Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-20-2008, 08:46 AM
continentaldrifter continentaldrifter is offline
Prospect
Default unbelievable vibration in fairing
I've got an 07 SG, when rolling up and down through 1700-2100 rpm, the fairing vibrates like no other i've seen or ridden. took three other 07's out to compare and there was no vibration. Brought back to dealer, they did a warrantee issue on the front motor mount .......no change. Checked ALL mounting tabs under the fairing..nothing. Checked all other motor mounts, looked for nuts or bolts that might've fallen between.........nothing. Wondering if anyone else has this issue. The vibration is so bad, its skipping cd's. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
"A Hungry Warrior Never Starves"
http://i28.photobucket.com/albums/c2...taldrifter.jpg
Old 10-20-2008, 08:48 AM
harley-jones harley-jones is offline
Tires?
Old 10-20-2008, 08:58 AM
rocknrod's Avatar
rocknrod rocknrod is offline
You need to check you fairing brackets inside the fairing.
They may be cracked.
__________________
http://i220.photobucket.com/albums/dd285/capstain/2.jpg
Old 10-20-2008, 09:01 AM
wassup8687's Avatar
wassup8687 wassup8687 is offline
Quote:
I know you said the dealer checked the mounts but I'd have them double check to make sure the brackets are OK.
__________________
2008 105th Ultra Classic
SOOS Floorboard Extensions
Old 10-20-2008, 10:01 AM
pop1's Avatar
pop1 pop1 is offline
+1 on checking the mounts. Take the windshield off then remove the fairing and have a look for yourself.
__________________
2003 Electra Glide
2008 ULTRA VIVID BLACK---SOLD
2005 ROAD KING CLASSIC---SOLD
2004 FAT BOY-------SOLD
2000 SPORTSTER 1200---SOLD
Old 10-20-2008, 10:29 AM
Dennydp's Avatar
Dennydp Dennydp is offline
Check front tire balance/bent or damaged rim.Check fairing brackets
__________________
Happy owner 07 Ultra
V&H trueduals-Rhineheart slip ons-Techlusion-Doherty air cleaner-IDS-Hogtunes-TWR Stabilizer and more and 97 Roadking around town bike
Old 10-20-2008, 10:38 AM
dougbk's Avatar
dougbk dougbk is offline
Sometimes you can't the bracket is broken until you loosen it.
__________________
Work Ride- 2008, FLHTP
2006 Ultra Black Cherry/ Black Pearl, 88", Thundermax AT, Andrews 26G
SE 6-Speed, 3.37 gearing, Rush 1.75", K&N Air
1989 FLHTC
Blue Knight Special (#75 of 75), 89" S&S Stroker, Mikuni HSR 42
Old 10-20-2008, 10:52 AM
BadPiggy BadPiggy is offline
Sounds like a broken fairing bracket...or 2.
Remove the outter, have a look at the brackets.
__________________
'06 Street Glide...Branch Heads-JE/Branch 95" Pistons-S&S 585 Gear Drives-Feuling Oil Pump & Cam Plate & Lifters-Jim's Roller Rockers-Delkron Rocker Support Plate-S&S Pushrods-Mikuni 45mm-NOS-Baker DD6-Baker +1 Oil Pan-Pioneer-Polk Audo-Biketronics Amp-Covered in PM Bling...too much stuff to list.
Wanna know what else is on it...PM me!
Old 10-20-2008, 11:55 AM
vindyl's Avatar
vindyl vindyl is offline
I AGREE broken brackets. pos harley brackets when you fix it pop rivet a heavy gage l bracket in place and it is done thats i have done to mine
__________________
C:\Documents and Settings\chris mcmillion.DR2RBBR51\My Pictures\eg glide_sig(1) (1(2).jpg
Old 10-20-2008, 08:14 PM
Harleypingman's Avatar
Harleypingman Harleypingman is online now
You can easily check the fairing brackets without removing the outer fairing.
Hold the left grip with your right hand and push the fairing away from the grip with your right hand--there should be virtually zero movement. If the fairing moves noticeably, the bracket on that side is broken. Repeat on the right side.
If the bike travels freely, without vibration, I doubt that you have a tire or wheel problem.
__________________
CMA, Crossties Chapter (GA)
IBA 26580
'04 FLHTPX
Tags
bad, dynamat, fairing, faring, flh, flht, front, glide, hd, motorcycle, mounts, put, rubber, shake, shakes, stop, street, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
