Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-12-2008, 02:15 PM
iclick's Avatar
iclick iclick is offline
Default '07 Fork Oil Change
The procedure in the '07 service manual for a fork-oil change specifies removing the fork, fork-tube plug, and spring (among other things)--then inverting the fork for the fluid to drain. Looking at the parts manual I can't figure out why you couldn't simply use the drain plug, then remove the top plug and add the new oil from the top.
For those of you who've changed the fork oil in your '06 or later FLH, here are some questions:
(1) Is the fork-tube plug (45838-77) hollow so that oil can pass through it when added from the top hole?
(2) Will all fork oil drain from the drain plug, assuming the forks are pumped repeatedly?
If the answers to both are "yes," I can't see why a fork-oil change wouldn't be only a matter of draining, moving the top plug, then adding oil at the top.
Changing the fork oil in my old '96 RK was a 15-min. proposition by just draining and applying a vacuum at the schrader valve to suck the new oil in through the drain plug. If all the oil could be drained from that fork, why not the newer models? I'm not talking about cartidge type forks, but the forks HD has been making for the past few years.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2007 Street Ultra
Stage 1½: Fuel Moto Power Package, SE255 cams.
http://www.iclickphotos.com/Motorcycle/0000-080702-04aLH-Bike.jpg
Link to larger image
Old 08-12-2008, 02:25 PM
ezlife's Avatar
ezlife ezlife is offline
Should be able to drain and refill using "wet" capacity. Replaced my lower sliders with chrome a few thousand miles ago and after putting back together filled through top plug, no issue.
__________________
Life's short and only a oneway ride, live it!!
2007 FLHRC
Old 08-12-2008, 02:47 PM
iclick's Avatar
Quote:
Thanks, that answers my first question. Now, will all oil drain out from the drain plug? I would assume that even if it didn't I could drain, refill, and repeat one or more times until the fluid is clear--then refill with the same amount originally drained. That might not be the best method, but if done every 10k it would be better than no change at all. Then at 50k do a disassemble and change it as per the book.
__________________
2007 Street Ultra
Old 08-12-2008, 03:02 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS IAMSWUTIAMS is offline
My bike had about 7500 miles on it when I put on the chrome lowers. The fork oil that drained out was sooo dirty, I don't think you could get it all out by removing just the plug at the bottom. What ever you end up doing, when you put in the new oil, use the heavier SE fork oil. It eliminates alot of the dive when braking.
__________________
2006 FLHTCU...........O~`O
http://i140.photobucket.com/albums/r9/IAMSWUTIAMS/antiquebikeshow08022-Copy-1.jpg
Spay & Neuter your pets, and don't play with matches
we're screwed now
Old 08-12-2008, 07:14 PM
iclick's Avatar
Quote:
I was planning on using the SE oil, or another 15W. I may try draining from the bottom and perhaps cycling new oil several times to clean it out by pumping the forks.
__________________
2007 Street Ultra
Old 08-12-2008, 07:21 PM
dswansbiker dswansbiker is offline
Senior Rider
I've heard before that some of the dealers have a cool piece of apparatus that sucks the old fork oil out and replaces it with new through the drain hole. This sounds like a good way to go if there is such a thing. Anybody know for sure?
__________________
Dave Swanson
2002 RK
1969 FLH
1964 XLCH
1956 KHK
1956 FLH
Old 08-12-2008, 07:48 PM
iclick's Avatar
Quote:
This works great on older bikes with air forks. I did this every 10k miles on my '96 RK and the entire job took about 20 min. I used a $10 venturi vacuum device from Harbor Freight Tools that connects to an air compressor to create a vacuum. Just plug it into the schrader valve (valve removed) to apply the vacuum.
I don't see an advantage to using this method with newer bikes, as you'd still need to remove the top plug to release the vacuum in the fork, and if it's already off you might as well install the new oil from the top. If you could seal the opening you could apply the vacuum from the top and suck it through the drain plug as with the older bikes, but again I see no advantage to going to the extra effort.
__________________
2007 Street Ultra
Old 08-12-2008, 07:57 PM
tailgater tailgater is offline
Hang Around
I ride an 07 ultra and this is the way I change fork oil.
1. Remove outer fairing.
2. Remove radio-to access top fork caps.
3. Remove top cap from one side.
4. Remove drain plug from that side and drain.
5. Slowly fill with oil from top and slowly work forks up and down until full.
6. Repeat for other side
__________________
Tailgater
Old 08-12-2008, 11:20 PM
It's not supposed to be "full" There is a specific amount of oil needed in the forks.
__________________
we're screwed now
Old 08-12-2008, 11:55 PM
iclick's Avatar
Quote:
I assume you mean by this that you fill from the top and slowing work forks up and down until filled with the specified amount (10.8 oz.) of oil.
BTW, you can access the top plugs by removing the ignition switch and fairing cap, which IMO is easier than removing the radio.
__________________
2007 Street Ultra
Tags
07, 2005, 2006, 4585877, capacity, change, davidson, flh, flhx, fork, harley, hd, levels, oil, socket, sportster, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
