Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-05-2008, 05:09 PM
speckfisher's Avatar
speckfisher speckfisher is offline
Senior Rider
Default RE: shutting down rear cylinder
Mine will work in gear while the engine is running with clutch pulled at a dead stop in traffic. Simply reverse the throttle until the cruise light turns green. Cruise button must be engaged prior to this. I have noticed a real difference in engine shake and heat. Louisiana 99+ temps OUCH
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
"Ride it like you stole it, cause you never know when the hurricane will take your ride away"
Old 08-22-2008, 03:38 AM
BlockHead96 BlockHead96 is offline
I actually got mine to shut off the rear today in traffic. A longer than normal red light, while sitting there, the Head Temp Sensor finally kicked in, injector shut down, bike shook a little more than normal, hit the throttle, injector kicks in. I can see where this may help with minimal fuel savings. When the injector shuts down, the rear jug acts like a air pump and cools the rear jug down. At launch, it will stumble just a tad.
__________________
Master Tune TTS W/ Yuill Bro's Dyno tune, Ness Big Sucker, Rineharts
08FXDL
USN USS Constellation CVA 64 Tonkin Gulf 71-74
Old 08-22-2008, 03:55 AM
rick's Avatar
rick rick is offline
Quote:
Mine works like this as well except cruise doesnt have to be engaged.
__________________
<a href=http://i44.photobucket.com/albums/f24/rick3148/rkc08012.jpg target=_blank>http://i44.photobucket.com/albums/f2...8/rkc08012.jpg</a>
2008 Roadking Classic w/stage1,heavy breather,PC-V
CFR slipons/dual headers
Old 08-22-2008, 04:02 AM
biz44's Avatar
biz44 biz44 is offline
Quote:
Originally Posted by sgl0226 View Post
Is there any disadvantage to setting the rear cylinder to shut down at idle (08 and later touring models)?&nbsp\\; If no disadvantage, why wouldn't you do this routinely when riding in warmer weather?
No down side to setting and forgetting it. On some 08' models you can turn the system on and off at will....and on early build date 08's you need the reflash IIRC.
Quote:
Originally Posted by Proboscis View Post
I'm still trying to figure out how to shut it down in heavy traffic. I remember reading something on here, but I don't think it said how to do it.
To turn the system on you roll the throttle off and hold it for three seconds. The cruise light will flash green for on and red for off(it dont matter if your bike has cruise or not...that year range will have the cruise light in the speedo anyway.
Have to set it when you start the bike.&nbsp\\; On 08 touring bikes (after a certain build date), you turn on the ignition, turn on the run switch, then roll the throttle away from you for about three seconds.&nbsp\\; The cruise control light comes on.&nbsp\\; Then you start the bike and it is programmed to shut down the rear cylinder at idle.&nbsp\\; Someone said it only does it when the engine is overly hot, but I thought it was everytime you come to an idle.&nbsp\\; I was just wondering if there was any disadvantage to setting it this way everytime I ride the bike in warm weather.
The bike does not have to be running to turn the system on or off. Just turn the key and kill switch both to run position. Roll off the throttle, and hold for 3 seconds.....then the cruise light will flash red=off/green=on. You can ride the bike with the system off, and then if you hit heavy traffic, while at a stop just turn it on via throttle roll off.
The rear cyl will shut down ONLY when several conditions are met....high engine temp, clutch in or in N, throttle no more than 2% open, bike at a stop. If any of these conditions change the systen turns off, and the rear cyl starts getting fuel again.
My bike came from the factory with the default setting of "on", and I just keep it that way.....at least for the Summer. I may turn it off come the winter though.
IIRC the realdeal low down on this system is on page 140 of the 08 tourong service manual.
__________________
F-around...F-around, soon you wont be around!
03'FXSTD-SE CVO Screaming Eagle Deuce.
08'FLHX Street Glide in Dark Blue Pearl.
<a href=http://i79.photobucket.com/albums/j146/stevef_02/bouncing-boobs.gif target=_blank>http://i79.photobucket.com/albums/j1...cing-boobs.gif</a>
Old 08-22-2008, 05:55 AM
Aslan's Avatar
Aslan Aslan is offline
MY 08 is an early build. If I have it flashed will I be able to turn it off and on like later builds or will I will be set to on all the time?
__________________
2008 Road Glide
"Duty by Heritage"
Old 08-22-2008, 06:45 AM
The Old Man's Avatar
The Old Man The Old Man is offline
Quote:
I have an early 08. IF you have it flashed to ON by the dealer it will work and work well. I have had it come on a few times this summer in traffic. I also ride in the winter, down to 18 degrees is my record. At lower temps there is no reason for it to activate so its no issue. Believe me at 18 degrees I want heat LOL...........
__________________
White, straight, Republican male (How else can I piss you off today!!)
Old 08-22-2008, 10:05 AM
Mars Mars is offline
Prospect
You enable the feature with the throttle but it is a programmed function and you do not directly control it. I have an 08 UC and last week in hot heavy traffic my rear was shutting off periodically. It is not like it turns off for a while. It actually cuts out only for a moment and then back on again. Sort of oscillates on and off. It causes the sound and feel of the motor to change while you sit in stifling traffic. Turns on without a hitch when you hit the gas or start rolling. The flash is for first-half 08's and all 07's. It uploads the software for the cutout. It is just one more function and worth doing if you don't have it but not in any way a big deal. Again, you dont turn off the cylinder with the throttle.
__________________
"What do you mean they cut the power?"".
http://i2.photobucket.com/albums/y30/rrrtttyyy/084346.jpg
Old 08-22-2008, 11:07 AM
Weavr99FLHT's Avatar
Weavr99FLHT Weavr99FLHT is offline
Prospect
once again. The rider cannot, at will, shut down the rear cylinder - the rider can only Enable the EITMS or disable it. (pre 12/07 08s and all 07s need a flash to enable and a flash to disable). for later 08s and 09s- the rider an enable or disable using the throttle. once enable, the ECM decides when to "shut down" the rear cylinder.
once enabled the following conditions will trigger the ecm to engage EITMS mode (some call it parade mode).
Head temp>287
below 1250 rpm (I think - have to look it up again)
neutral or clutch disengaged
below 2 mph
if above conditions are met for a specified period of time, the ecm will cut the fuel and spark to rear cylinder - it becomes an air pump. you may hear a change in engine tone, and rpms may drop slightly.
when any of the following conditions are met, spark and fuel are turned back on
head temp <275 (or something like that)
rpm above 1250
clutch engaged in gear
above 2mph
You can enable and disable, the ECM turns it on and off.
__________________
One Road at a Time - 48th State ridden: July 5, 2008 - 1999 FLHT - Retired @ 68,786 miles
2008 FLHTC Crimson Red Sunglo - Startin' Over
http://www.hdforums.com/forum/image.php?type=sigpic&userid=56699&dateline=121821  4562
Old 08-22-2008, 03:30 PM
Aslan's Avatar
My 08 bike is running great. The bike gets a little warmer than my old one but nothing like what some people have written about.
I live in the Northeast so I don't get that many real hot days.
I think I will just leave it alone. If I plan on running to a different part of the country where I will be in areas of prolonged high heat I'll get the flash.
__________________
2008 Road Glide
"Duty by Heritage"
Old 08-22-2008, 03:35 PM
HiPlainsHeritage's Avatar
HiPlainsHeritage HiPlainsHeritage is offline
Prospect
"Parade" mode is different for the touring models as compared to the Softail bikes. Both have to be flashed on to the bike, but the touring models have more control over the operation of EITM. For the Softails it is more of an off/on operation with no operator control.
That is if I am understanding things correctly.
__________________
2008 FLSTC
Tags
eitms, engage, harley, hot, operation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
