I use to have a Buell X-1. \\;I road it like it was stolen and loved it. \\; Coming back from Iraq I bought a 08 FLTR Anni and in 3 months I have logged 7K. \\; Most of it being back roads I found a slight "shim" if you will, when I was taking corners at moderate speeds. \\; I then read about true track and I understand that it is for reducing wobble at high speeds and assists in the corners. \\; Are there any secondary or tierchary effects for getting true track installed? \\; Do I sacrifice comfort for cornering? \\; Removing the purpose of rubber mounted engines with a third stablizer must do something else to its designed characteristics. \\; I have to ask myself if I am still riding this touring bike like it is a Buell sportbike? \\;
 \\; \\; \\; \\; Naturally, when I went in for my 5k service, they tightened nearly 60 percent of the spokes and they said that the shim was probably ddue to loose spokes that would cause a slight wobble in the corners. \\; I took it out again and everything seemed fine.
 \\; \\; Is there a need for true track if you have a stock engine and no mods to the powertrain? \\; The jury is still out with me.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
[/SIGPIC]"If you are not going to be safe...be famous!
'08 Ann FLTR
SE2 pipes (96Bs)
Stage I
HOGTUNES
__________________
06 Road Glide se stage 1 a/c se mufflers mustang seat custome chrome parts
Arlen Ness Hotshot ton of kuryakyn harley thunder star rims arlen ness / h-d a/c fullsac
true duals AMSOIL DISTRIBUTOR FOR SAN FERNANDO VALLEY
Tru-Track, Ridestr8, TWR Missing Link all work &\\; your FLTR will be a much better bike with some kind of stabilizer on it. \\; Tracy's TWR Missing Link is just a better buy, &\\; you don't loose any ground clearance. \\; Do the research &\\; buy the one you like, but do get yourself a stabilizer!
__________________
Jinks ('86 FXRS, '07 FLTR)
#64
Remember, "No good deed goes unpunished"
I understand that there are some stablizers out there. \\; But am I substituting corners for comfort? \\; Being in the military, when I get a three or four day pass it means a three or four day ride. \\; Also, can anyone answer my last question. \\; I would think that if you beefed up the engine or intake, it would effect the torque which would inversely effect the rubber mounts design requiring a need for an additional stablizer. \\; Thoughts?
__________________
'08 Ann FLTR
SE2 pipes (96Bs)
Stage I
HOGTUNES
I understand that there are some stablizers out there. \\;\\\\\\; But am I substituting corners for comfort? \\;\\\\\\; Being in the military, when I get a three or four day pass it means a three or four day ride. \\;\\\\\\; Also, can anyone answer my last question. \\;\\\\\\; I would think that if you beefed up the engine or intake, it would effect the torque which would inversely effect the rubber mounts design requiring a need for an additional stablizer. \\;\\\\\\; Thoughts?
Adding a stabilizer only effects the lateral movement of the swing arm. \\; The rubber mount still works in the vertical plane. \\; Your ride comfort is unaffected with the exception that the entire machine is a lot more stable. \\; The only thing you loose is the loose/wallowing feel of the frame. \\; The new stability will actually improve your speed since you'll have more confidence in the way the bike handles.
__________________
#64
Any of the stabilizers (Ride Str8, TWR, Alloy Art, and True Track) do basically the same thing, which is to stabilize the lateral movement of the swingarm, but with the exception of the first two are quite different in design. After considerable research I decided on the Ride Str8, but that was one year ago, and since then the TWR has appeared. It is an almost identical design compared to the Ride Str8 but is considerably less expensive. There is no compromise in comfort, i.e. no increase in vibration. Here's my write-up on the Ride Str8, explaining why I selected it over the other options:
I recommend the TWR or Ridstr8 over the True Track, because you are obviously an agressive rider, and they won't scrape the ground on a sharp turn if you have lowered your bike, or plan to. \\; True Track is a much quicker installation. \\; The TWR is a fantastic product at a lower price, which is why I went with it, and have been extremely satisfied. \\; Contact sifularson, and he'll be able to help you get hooked up with Tracy if you are interested in the TWR.
How much difference will it make on an Ultra? I am a pretty straight up rider and don't take corners too hard and fast but have felt some instability at times.
__________________
Say what you mean, mean what you say.
Honestly, with your ridding style, I would save your money. JMO, but this is only really necessary if you push things some in the twisties.
Quote:
ORIGINAL: reeac
__________________
07 FLHX
Zumo 550 w/ XM Radio
IDS, Cruise Control,Hog Tunes Ultra Sound
Tour Pack and Lowers
204 Cams, Monster Ovals,T.W.R. Missing Link Stabilizer
WILL THIS EVER END?
