Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 04-27-2008, 09:59 AM
EdwardK EdwardK is offline
Senior Rider
Default RE: Reason MOCO went to TBW? Opinions?
Quote:
ORIGINAL: Uncle Scrooge
I guess that makes sense, butthe improvement would seem slight unless the bike's being driven by someone with palsy. Any hard numbers on the improvement? Is it enough to justify the added complexity and expense of the TBW?
Complexity and expense??? It's simple technology. It's just a potentiometer that have been around since the beginning ofelectronics. ( i.e. volume knob on a radio ). Also, in the manufacturing process, it's cheaper and faster to install. It plugs in. No cables to adjust, no brass cable end to drop. Less labor to build the bike.
You people should be more open to improvement. You used to get off the couch to change the channel on the TV bet I bet you don't do that anymore either. You spend ten minutes looking for that dam remote instead of using the dial.
I love my TBW for 11,000 miles no. Works great!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
http://www.chromekitsch.com/
2008 Road King Classic, Pewter Pearl, Rinehart True Duals, SERT, SE Air Filter
Traded in my 2005 Nightrain, Vivid Black, V&H Big Radius, K&N Air Filter 45,000 miles
Old 04-27-2008, 10:20 AM
YodaddyKeith YodaddyKeith is offline
TBW places the computer in full control of throttle......the twist grip is used for you to input your desires...the ecm then responds as per it's programed curves.
You can dial up wide open throttle, but bike will respond only as ecm allows.....ecm uses muli inputs to determine how fast bike acells/decells and will not allow bike to polute like with cables.
Old 04-27-2008, 10:34 AM
Uncle Scrooge's Avatar
Uncle Scrooge Uncle Scrooge is offline
So the service manager at my dealership will charge me less to work on TBWthan on a conventional cable throttle?
__________________
06 ElectraGlide Classic
Old 04-27-2008, 11:05 AM
Gart Gart is offline
Senior Rider
Quote:
ORIGINAL: jpooch00
Does anyone know why the MOCO went to the TBW system after 104 years of cable controls that worked perfectly well and which were cheap and easy to maintain and/or replace? It seems to me that having a simple cable system to force the throttle open or - even more importantly - closed rather than relying on a bunch of electronic/electrical components and connections is just plain common sense.
Well, I might have answered my own question right there!!
Anyway, any info is much appreciated.
John
If there weren't any technology advancements over the last 104 years, we would have to ride single cylinder, low powered, uncomfortable bikes such as the 1903. Drum brakes worked fine until disc brakes came out. Points/condensor worked until electronic ignition, ridgid front/rear was fine until suspension was put on, generators before alternators, etc.
You get my drift. There will always be change. It may take time before one is comfortable with it.
Old 04-27-2008, 11:30 AM
BCguy's Avatar
BCguy BCguy is offline
I've been thinking about this TBW system and it seems to me that all that's been done is to move the controller (a potentiometer) that provides input to the ECM from a location on the throttle body (cable actuated) to a location on the handle bar twist grip. It's only a wire extension, everything else is the same. Does this make sense?
As to why it was done, I believe it had something to do with space available.
Oh yeah, I rode my new, TBW equipped RG home yesterday and I couldn't tell the difference. It felt just fine!
__________________
2008 Crimson Red FLTR, ABS, V&H Ovals, SE a/c, Cee Bailey's, HoggChopps
Pro libertate
Old 04-27-2008, 11:34 AM
FX4 FX4 is offline
Quote:
ORIGINAL: Gart
Quote:
ORIGINAL: jpooch00
John
Here, here! I often think Harley riders are a bunch dinosaurs just insisting the brand goes extinct. We will have no innovation damn it. I want my 20k bike to be an outdated dinosaur.
__________________
2007 Street Glide - Formerly a clattering bucket of bolts.
Frikken Stock!
Old 04-27-2008, 11:37 AM
oldfartjc's Avatar
oldfartjc oldfartjc is offline
Send a message via MSN to oldfartjc
Quote:
ORIGINAL: russl179
Quote:
ORIGINAL: FX4
1. Emissions
2. Fuel economy
OK, with the same size engine and fuel injection system, how can the TBW enhance emissions and fuel economy?
+1 Please tell us how, I always like to read a good piece of fiction.
__________________
2006 Road King FLHRI/Deep Cobalt
Stage 1/SE A/C K&N Filter/SERT
SE Pro Performance Exhaust
Old 04-27-2008, 11:40 AM
Senior Rider
I'm not going to deny that the part may cost more but the laborshould be less. It will be a lot easier to change. But then again, I bet they are both as reliable a
__________________
Old 04-27-2008, 11:42 AM
Mississippi Bagger Mississippi Bagger is offline
Quote:
ORIGINAL: YodaddyKeith
This is the main reason I do not like the TBW. I am all for advancements/improvements, BUT NOT ones that put a layer of separation between me and my bike.
I LIKE being able to turn off the fuel, I like having a reserve, I LIKE having a choke, while I would not mind having an auto tensioner for the primary...I LIKE having an inspection plate to be able to check the primary.
__________________
05 Road King Custom
Carburated
SE Stage 1 w/ K&N
Custom Fuel Moto Rush Slip-ons
HQ 0034 Cams
Old 04-27-2008, 12:44 PM
FX4 FX4 is offline
Quote:
ORIGINAL: oldfartjc
Quote:
ORIGINAL: russl179
Quote:
ORIGINAL: FX4
1. Emissions
2. Fuel economy
1. Dinosaur
2. Read the posts in this thread - I know its hard but you just may learn something
__________________
Frikken Stock!
Tags
1800, bodies, chat, complaints, consumer, davidson, hack, harley, moco, pak, remove, retrofit, tbw, throttle, tour, vtx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
