How long does the alarm sound when activated? I did this last summer and when I shake my bike to set off the alarm, the siren sounds only as long as the turn signals flash. In other words, about one second.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
06 FLTRI No habla jibber jabber!
takes longer to post pictures than do the job. Under left side panel, the plug is on the left side of fuse box. just unclip and put the red wire of the siren into brown hole of plug and black wire of siren into the green hole of plug. do not cut the plug off, just stick wires into holes and tape up and stick the siren on the side of fuse box. took 15 min really
__________________
DREAMRIDERS Biking for Children
Love, Loyalty, Respect
08 FLHX #1023
dreamriders.us
If it is installed correctly it might take a couple bumps or stood up.
Mine is a bit like that.
The first sign of movement the systemgives you a warning, the lights flash and the siren gives a short yelp. If you keep messing around it goes off and stays on for a while. My forks were unlocked so without the fob I turned the switch to ignition. The radio and lights came on and I thought well crap it doesn't work so I turned the run switchon and I heard the fuel pump start up.Again, I thought it doesn't workand someone could be stealing mybike and I hit the start button.
ALL HELL BROKE LOOSE [sm=yikesomg.gif]I almost wet my pants running for the fob...the I don't know how long because I shut it off. It works!
I picked up the Shiet Shack Siren today....Thanks to this thread.....Crypes for a mere $5.87 why not give it a try......I am certainlygoing to!
FYI if anyone goes into their local Sheit Shack.... The beepers will be found in a metal drawers with capacitors and frit frats and the likes in the back of the store.... The drawer you want is color coded purple and that iswhere you will find the beepers. There a bunch of different ones...So make sure you write down the part number listed above.
What your hearing is the audible warning. If you have the bike "armed" and you turn the ignition and try to start it, it will actvate the alarm long enough to make you feel like a complete ( l )! and will stay hollering until you take the fob and deactivate it! Works well in crowded parking lots to bring much unwanted attention to yourself! LOL
The one in the DYI mod section. I gotta give two thumbs up to whoever originally came up with that idea. It works like a champ!
Thanks, that would be me. It helps that our oldest son is a manager for RS so I get to go in there and experiment. I just don't understand why Harley sell/installs the alarm without an audible alarm.
