Notices
Just finished Boogey Lights install (photos added)
Old 01-28-2008, 03:32 PM
RonH's Avatar
RonH
RonH is offline
Default Just finished Boogey Lights install (photos added)
Some like 'em, some hate 'em. That's what makes these bikes so much fun to spend money on, do what you like right? So I like 'em and just finished installing the Ultimate Engine Kit from Boogey Lights on my EGC. Turned out very nice. Because of state laws against red and blue I went with the purple LED's. Not as bright as the other colors, but makes a nice subtle glow on the engine. Instead of their switch I wired them into the ACC switch and it's a slick, clean set up. Unless they're on you wouldn't even know that they're on the bike. Can't wait for some decent weather to get out on the road and see how it looks......
[IMG]local://upfiles/9233/B55C9F8DFE4341AE864C0907DC0CCF01.jpg[/IMG]
[IMG]local://upfiles/9233/7CAB072606E7437488440CDEB990DD1A.jpg[/IMG]
Old 01-28-2008, 03:35 PM
Phrogman's Avatar
Phrogman
Phrogman is offline
Default RE: Just finished Boogey Lights install
I thought a boogey was something you dug out of your nose...
Old 01-28-2008, 03:38 PM
rome304's Avatar
rome304
rome304 is offline
pics?
MustBBrent's Avatar
MustBBrent
MustBBrent is offline
need pics!!!!!
[sm=ttiwwp.gif]
I want some... need to see em at night!
Old 01-28-2008, 03:40 PM
CREEPSHOW's Avatar
CREEPSHOW
CREEPSHOW is offline
You can pic a boogey!
Old 01-28-2008, 03:46 PM
cirhere2's Avatar
cirhere2
cirhere2 is offline
seen them on alot of crotch rockets
Old 01-28-2008, 04:31 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
Hey Ron,,,, how was the install?
thats somethin Ive been thinking about,,,
would like em, can live with out them,,
if its not to big of a hassle, I'll go for it
Old 01-28-2008, 04:40 PM
RonH's Avatar
RonH
RonH is offline
ORIGINAL: electaRICK
There are very good and pretty detailed video instructions on the Boogey web site, but it's on a Dyna not a bagger. It's not that big of a job, but it does take some time. Figuring out where you want to place each strip is the first step. Trying to put them in places where the LED's won't be seen isn't as easy as you might think. Then they all connect together so you have to plan how the wires will run and connect them to the strips before you stick them in place. I had a lot of trouble with my breather, it's an SE and the back plate is very rough. I couldn't get anything to stick to it. So I finally took the whole thing off and filed down a smooth spot on the back. It also is not a level surface so used some 3M tape to build it up the center area to a level smooth spot for the 6 LED strip that I put there. So it's not an hour and you're done kinda job. But the results are pretty cool.
Old 01-28-2008, 06:34 PM
HB's Avatar
HB
HB is offline
[sm=ttiwwp.gif]
WEEEEEE NEEEED PIIIICS PLEEEEASSE !!!!!!!!!!
Old 01-28-2008, 07:33 PM
RonH's Avatar
RonH
RonH is offline
OK - snapped a couple in the garage...... see first post
Quick Reply: Just finished Boogey Lights install (photos added)
