Guys, keep in mind, this only functions at idle. \\; Anything off idle, both cylinders are firing. \\; My buddy had it flashed because he rides in parades and wanted it to work at slow speeds, but like I said, it will not kick in unless throttle is at zero position. \\; As far as turning it on and off, I would think once you enabled it, you would leave it. \\; It's automatic, based on temp and really not that noticeable. \\; It is nice, we rode through downtown Chicago in traffic and it kicked in a lot when we were sitting still. \\; Made me feel a little better about the torture I was putting the motor through, but let me tell you, me nutz was still sizzlin'.
__________________
"It's not about the destination, it's the journey that matters"
Have the nSERT Pro Tuner and yes, the function to turn it on or off is still there!Â*\\\\\\; Your dealer is smokin' rope!
Now the dealer is saying that the on / off feature can be enabled with the new tuner (Super Tuner or whatever its called) I have the older SERT tuner. My bike is there now for some warranty work they said they will call Harley to see if there is a work around.
I bought my 2008 in early spring, I just tried to activate this feature following pg 140 in my manual...no such luck, guess \\;I need the flash. \\; Will take care of same prior to Sturgis. \\; It better be "no charge".
__________________
RETIRED VETERAN
~AIRBORNE~
Combat Vets Motorcycle Assoc.
"Vets Helping Vets"
2008 Road King
Gulf War I/Allied Force/OIF 2/4
My buddy has a late build '08 SG with a SERT and he cannot turn the EITMS off/on with the throttle. My early '08 doesn't have the feature AND I have the SERT, so I guess the new ECM software wouldn't help me.
