Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-18-2007, 06:13 PM
davlyo davlyo is offline
Hang Around
Send a message via AIM to davlyo
Default 103ci SE ST Legal Big Bore upgrade
The Stage I kit increases the Bore from 96ci to 103ci. The Stage II kit increases the Bore the same amount but adds the SE 255 Cam kit (25638-07). What does the Cam kit add to my performance upgrade? I have always been told that inches are important -or -size matters. But the Cam kit isn't adding inches or size -so what does it add to the performance?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
davlyo
'07 Road King Custom FLHRS
Popping Spitting Sputtering Beast
Old 08-18-2007, 07:17 PM
Shovelhead Bob Shovelhead Bob is offline
HDF Tech Moderator
Default RE: 103ci SE ST Legal Big Bore upgrade
First off... Welcome Aboard... Please take a moment and post an intro in the NEW MEMBERS SECTION at your earliest convenience.....
The upgrade of the cams is important as it modifies the duration (Time) that the valves for the intake and exhaust are open or closed, to assist in getting more Fuel/Air mix intoand Spent gas' out of the combustion chamber....
Additionally, it modifies the SPECIFIC point of engine rotation (Degrees) when they are opening and closing...
By adding the SE 255 cams to your 103 kit, you will have a great deal better bottom end torque, as well as higher HP numbers when out on the interstate.....
Torque gets you moving.....
Horsepower makes you move faster.....
Old 08-18-2007, 07:57 PM
fxr_george fxr_george is offline
Prospect
Send a message via Yahoo to fxr_george
Quote:
ORIGINAL: Shovelhead Bob
No offence but the SE 255 are weak. I want to do the same SE 103 kit but the cams I will not use.
__________________
2008 FLHX
103" KIT STAGE II
REPLACED 255SE CAMS WITH 251SE CAMS
D&D FAT CAT 2:1 HEADER
STOCK 96"HEADS
SE HEAVY BREATHER AC
90 HP / 105 TQ +/-
billydflnc's Avatar
billydflnc billydflnc is offline
Prospect
Ditto... yea what he said !!!
__________________
'04 FXSTI 60K+,SE stage II 95,203 cams,SE 6spd,SERT,Vance & Hines,and CHROMED out!!90.3HP/100.7TQ
'08 RG 22k+,ABS,stage II 103,SERT,V&H duals, ,XM,detachable King Tour Pak,etc.!!!
'74 Super Glide,'77 & '79 Sportsters
Old 08-18-2007, 08:08 PM
sugarbear sugarbear is offline
What cams would you use for low end torque?
__________________
I don't think you heard what I thought I said!
'09 ultra
4" se slip-ons
sert
so much for stock
(just starting)
Old 08-18-2007, 08:39 PM
HDF Tech Moderator
Quote:
ORIGINAL: fxr_george
No Scheitt...... But the original question was in reference to the SE 255's.....
For that matter, why stick with a set of Flat-tops and stock heads with a wimpy and restrictive induction module??????
Those cams are a bolt in and the ECM configuration are PURPOSE DESIGNED to work with those specific components, without needing to revamp the valve train, add on a Fuel management system, etc....
Mods to "Kits" require very specific, and sometimes prohibitive measures that impact on durability, rideability, tunability and most importantly owner confidence....
Old 08-18-2007, 10:10 PM
dircha dircha is offline
Prospect
Quote:
ORIGINAL: davlyo
There are other cams that are better choices, but if warranty is a concern you should be able to find a dealership that will allow you to stay under warranty or at least extended warranty so long as they do the work and you stick to the kit straight out of the manual. In my case they did the heads too.
I guess if something goes wrong we'll find out whether they are actually going to stand behind it as they told me.
__________________
2007 FLHRC | SE Stage II 103" | '06 SE mufflers | SERT | 90 HP 103 FT/LBS
Old 08-18-2007, 10:17 PM
bigdaddy405's Avatar
bigdaddy405 bigdaddy405 is offline
Hang Around
Has anyone added the stage 1, 103 kit ( without cams) and what did it do for you please?
Say stage 1 , 103 kit, a good air intake, free flow exhaust & SERT. would it be worth it?
I am sure it would be a mild & reliable. Maybe make 75-80HP & 85-95TQ? anybody done this yet?
__________________
1999 FXST, SE heads, Woods cam, Hookers, Apes & solo seat.
2003 FLHT, tourpack, Reworked CV carb.
2003 Honda Shadow VTX- wifes.
Old 08-18-2007, 10:58 PM
sleepyjim sleepyjim is offline
Prospect
The 103 can be done with no kit to 07's TC96 by bore the cyl and new pistons, the motor is already stroked and all......The air, pipes and EFI are almost always done even if no 103 kit is.
sj
__________________
07 SG
103" , 255 Cams, Head work
K&N 3909, B&E Slip Ons
TMax, 13" Apes
Old 08-18-2007, 11:34 PM
Hang Around
Quote:
ORIGINAL: sleepyjim
sj
I know it is just a bolt in on the 07's 08's, I wanted to know how much the 7 extra cubes adds to the stock TQ or HP?
__________________
Tags
103, 2000, 2007, big, bore, breaking, davidson, flhtcu, harley, kit, overheating, problems, tire, upgrade, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
