Relocating CB antenna - need adapter advice
I have a "new to me" '13 Electra Glide Ultra Limited and am moving some stuff around. I've installed a detach kit for the Tour-Pak and have moved the AM/FM antenna down to the saddlebag frame. Now I'd like to move the CB antenna to the same place on the other side of the bike but it looks like I'll need some kind of Motorola adapter at the bracket to connect the cable to the antenna mount.
Anybody done this? Is there an adapter for this or will I have to replace the cable from the fairing to the bracket with a different fitting?
It's been a while since I relocated mine on my 2010 Ultra but here is what I remember. My local dealer sold me what I needed to relocate both antennas. If my memory is right each side cost around $30.00. I think they have a kit but you really don't need everything that is in it. I would just go see the dealer they can pull it up on their screen. Sorry that's the best I can tell you.
Had the detach kit on my '13 UC when I purchased it. Both antennas had the relocate kit, bracket and coax, to switch between tourpack mount or lower fender mount. Actually had the hidden antenna for the radio, but PO retained the antenna as a dummy for a symmetrical look when tourpack not used. I didn't use the CB, so both antennas were left off for a cleaner look.
P&A has kit for 14 and newer.
http://mstore.harley-davidson.com/st...relocation-kit
I seem to remember they were available for earlier since the detach kits were listed as fitting the Ultra and Limited
Thanks to all for suggestions. I contacted a couple Radio Shops and inquired if there is an adapter and they forwarded the problem to their techs and so far no answer as to finding an adapter. Local shop was stumped too.
It looks like I'm going to have to pull the tank and replace the original CB cable with cable p/n 76505-09 that fits the bracket, More work, but hey, you gotta spend your time doing something eh? I'll order one today from my dealer.
I've already placed hidden antennas in the fairing anyway so am just keeping my options open in case I ever want to mount those eye pokers back on the bike.
I would cut the cable, solder on my own connector, and install a base and antenna with more performance if it were me relocating the antenna. I realize most don't know how to do that so guess you are stuck with what the dealer wants you to have (and pay). If you are not using the chicken band very often, why even fool with it?
I relocated my CB antenna down there. The reception is terrible. In fact, the CB had very limited range when it was mounted on the Tour Pak. After relocating it to where you are, it was pretty much unusable. Couldn't even talk to other bikes in the group I was riding with. I just took it off altogether and moved the radio antenna to the fairing to get a cleaner look. I may move the CB antenna to the fairing too. I know that's not optimal, but it can't possibly be any worse than moving it down on the frame.
Done
Here's what I ended up doing.
I moved both the AM/FM antenna and the CB antenna to a mount
on the saddlebag frame. I capped them off because I'll probably
never use them there but just in case I ever do I wanted the option.
I got the adapter cable and coiled the cable connection under the seat.
I now have hidden AM/FM and CB antennas in the fairing with the option to
use antennas at the rear if I ever choose to.
