Ohlins rear shocks and tire changes
I ran into a minor issue today. I have the Ohlins #6 (HD-357) on my 2011 Ultra and I wanted to install a new rear tire today (it sure is convenient have a No-Mar tire changer). Seems as though the bottom eyelet on the Ohlins shock has a larger diameter than the stock Harley air shocks. I measured:
stock Harley air shocks: 1.130"
Ohlins #6: 1.300"
What does this mean? At first it confused me since I could not figure out why my 36mm rear axle wrench (OTC Tools #4882) that I've used in the past didn't seem to fit on the axle nut. Even my old Harley Combination Axle Wrench (3/4" and 36mm 94695-08) would not fit. I had to loosen the top shock mounting bolt and remove the lower mounting bolt.
Has anyone else noticed or run into this issue with their Ohlins?
Ohlins #6: 1.300"
I have a commercial 36mm open ended wrench and a socket, haven't had any problems in the last 6-7 years and I've had that darned wheel out often enough (messing with a non-stock wheel). Having slackened the nut I usually work with the bike on a lift under the frame, so have plenty of space under the axle.
Just to be clear, these are the type of wrenches I am talking about. All of which I own.
Lang Tools 9636 - REAR AXLE 36MM NUT RATCHET WRENCH
http://www.langtools.com/sku-9636-re...atchet-wrench/
OTC Rear Axle Wrench #4882
https://www.otctools.com/products/rear-axle-wrench
Harley 36 mm Combination Axle Wrench
http://www.harley-davidson.com/store...h---3-4---36mm
I didn't even think of this. In the past, I would always pull just the left side slip on, which was always a chore even though I would re-install it using plenty of anti-seize. Are there any issues I should be aware of when adjusting the belt tension with the swing arm up high?
I have only had the rear tire off once and I had it on a jack so I was able to move the bike up and down easily. I set the belt while at approximate ride height and then reinstalled the shock. At the time, I had stock shocks but the procedure would be the same with the Ohlins. I went this route after fighting with the slip on for an hour.
Just wanted to post a follow-up to this thread.
A rear axle wrench *may* fit. It depends upon the position of the rear axle adjuster and how much your rear belt may have stretched. I ended up using two 36mm sockets.
I was going to remove the lower shock mounting bolts but didn't want the hassle of trying to figure out the correct swing arm position to adjust the belt tension. I just bit the bullet and removed the right side slip-on. Sprayed some WD-40 on it, and used a strap wrench to turn it and loosen it up. Took a bit of effort and time but I won the battle.
Re-installed using anti-seize like I have in the past.
Noticed that there was slight contact between the rubber on the worm gear clamp on the reservoir and the saddlebag so I made a new mounting bracket that moved the reservoir over 1/4" to the left. Since there is no drive pulley on the right side, there was plenty of room.
Didn't have any issue with my #6 Ohlins when changing out my rear wheel for a rear Agitator and new rubber. Certainly didn't have to fool with loosening the shocks. I remove both mufflers so I can get to stuff easily and it's a snap if you use the right tools and get the bike's rear end up high enough. Here's some shots of my Ohlins without the mufflers obstructing the view:
Bagger11
2014-2023 Touring Models
08-15-2017 05:35 PM
ohiomike
10-03-2016 07:21 PM
