Higher bars on an Ultra/Limited
There are plenty of bars out there that you can run without changing the brake or ABS line.
Like...WO578, WO577, Reapers 10-12", KST Mayhem 10-12", Monkey Bars 10-12", Road 6 customs 10-12, LA Choppers 10-13" and a bunch more.
Not all of these look great with stock lines, so check out this thread and all the pics etc.
https://www.hdforums.com/forum/new-r...-the-apes.html
Yes. What I mean is don't change bars assuming the stock cables will fit so you are unprepared to invest more money on longer cables and or brake lines. I've been in that position before. So I learned, if I'm changing bars, I will more than likely be changing cables. I don't like to try and rerouted them and stretch them tight when turning the bars. I prefer to have the right length cable and brake line to keep close to factory routing. As I said in a different thread on this subject, and inch too long is better than an inch too short.
I was in the same boat but I waited and tried several people's bikes until I found the style and size I wanted...
If the bar you need is taller than what you budget allows, wait, do it right the first time and be done.
That thread applies to Limiteds.
Anyway, what year? SBates was right about there being a difference in what is possible depending on year.
Not all aftermarket bars accept stock Harley heated grips.
In his defense, you are the one that said on a budget....to some that means the cheap way out....
Thanks for the response!
