I'm doing a Road King Custom dash conversion and I have everything except the plate that the center mounting stud sits in, and I cant seem to find it or a part # to go by. Any help would be greatly appreciated !
I'm not opposed to making it but would rather use the factory part if at all possible. If I cant come up with it by the time I'm done with paint and get all my powder coating back I will just make my own.
Thanks, but I have the stud, actually a couple of them. I'm looking for the added plate the stud slides into that's bolted on the lower end of the fuel lever sender plate, its specific to only the FLHRS ( Road King Custom ) since the mounting stud ( #3 ) is further down than on any other Road King models . So far no parts break down shows it !
Looks like that bracket came in the 71306-04 Upgrade Dash Kit (not sold anymore) to install a RKCustom dash on a Std RK or RKClassic. No part# and "Not Sold Separately". They may have also used that bracket on 2004 only RKCustoms (even though they don't show it now) because they show the same fuel pump assy with top plate as the RK and RKC and there would be no way to mount the custom dash without that bracket.
Unless you happen to find one or make one, you'll need to change your top plate to a 2005 RKCustom (FLHRS) 75110-04 TOP PLATE $52.27 (Top Plate is used in 75227-04A FUEL PUMP ASSY).
Thanks, Finally got some useful info !! I'll look into finding a 05 or newer top plate and if that don't pan out it looks like I'll be fabbing up a mount.
Thanks again
Well I think a simple fix could be had ? Maybe take some strap steel 1 inch or so wide, nut and bolt to existing mount slot and drill a new hole ?? If the height were different the metal could be Z bent ? Hmm I will figure something totally hillbilly made from junk in the garage from my Fred Sanford collection.
