Oil leak ??? Help
That is one of your bolts for the valve cover. Covers been off? Is it loose? There is a $6.00 gasket under the cover that circles the bolt. Obviously, the bolt is loose or who ever had it apart did not replace gasket. Harley applies some type of spray on the gaskets that make them so oil tight now days. Most all the covers need a rubber mallet to un-stick them. It would be normal for oil to fly up under the spinning rocker arms. However, you might want to start motor and check oil level with it running. Oil level should stay on stick if the return system is functioning properly. No big deal. Just a minor fix.
If bike was recently serviced by someone, I would wipe it off if you pay for service and make sure it come back. Could be the old shot of oil on the shock trick.
