Speedometer Signal Code P0505
Old Aug 6, 2005 | 01:12 AM
HDF Tech's Avatar
HDF Tech
Default Speedometer Signal Code P0505
Tech Tips Online
June 17, 2002
Speedometer Signal and Code P0505
The speedometer signal is an extremely important input for the Delphi fuel
injection system. The ECM monitors throttle position and speed signal inputs in
order to properly maintain the set idle speed. If the ECM loses the speed signal
for any reason while the throttle is closed, the ECM assumes the vehicle is
stopped and will adjust the idle air control counts to bring engine rpm to the set
idle speed. This could set a P0505 code and adversely affect engine idle.
Source: http://www.harleyhog.co.uk/
minar
Sep 26, 2018 04:04 PM
chaos5
Sep 26, 2018 10:00 AM
Z
Aug 13, 2018 08:49 PM
WarBaby1946
May 7, 2014 05:09 PM
Handycam
Sep 17, 2010 07:17 PM
