Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-04-2009, 11:10 PM
meathead1134 meathead1134 is offline
Hang Around
Default screaming eagle cams worth it??
I had my 04 883 converted to a 1200 and I didn't add cams. The bike really screws right now. Is it worth adding the cams now??
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 11-05-2009, 07:04 AM
jrmotorsports55 jrmotorsports55 is offline
Hang Around
Thinking abolut adding these to my 07 1200C as well. Not planning on doing much other than exhaust/intake/tuner.
Jason
Old 11-05-2009, 07:20 AM
xFreebirdx's Avatar
xFreebirdx xFreebirdx is offline
Cams are useless without headwork.
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
1996 HD 1250 XLH
Old 11-05-2009, 09:20 AM
OldFenderGuy's Avatar
OldFenderGuy OldFenderGuy is offline
If you did nothing more than boring your bike from 883cc to 1200cc the performance increase will amount to nothing more than increasing the displacement.
To gain real performance you at least need to run the stock highers flowing cams and modified Buell heads from the 2004+ 1200's.
Far as the Screamin' Eagle cams, I added SE "E" cams to my 2005 1200C and picked up an additional 7 or so horsepower to the rear wheel.
But like others mentioned, won't do much good to install higher flowing cams if you are limited by the stock 883 heads...
Here is a little information HD released dealing with the 2004+ 1200 engines;
"The XL Evolution 1200 engine has high-flow cylinder heads with an oil drain-back feature. The XL Evolution 1200 engine is also fitted with high-performance cams for enhanced torque output. Compression ratio is 9.7:1.
The XL Evolution 883 engine is rated at 53 peak horsepower at 6000 rpm and 51 ft. lbs. of torque at 4300 rpm. The XL Evolution 1200 engine is rated at 70 peak horsepower at 6000 rpm and 79 ft. lbs. of torque at 3500 rpm, an increase of more than 15 percent over the previous XL Evolution 1200 engine".
__________________
"Magna Res Est Vocis Et Silentii Temper Amentum"
(The Great Thing Is To Know When To Speak, And When To Keep Silent)
And By The Way; I'm Not Your "Bro"..
Old 11-05-2009, 10:05 AM
Flatlander's Avatar
Flatlander Flatlander is offline
Cams alone no. If you really want to notice a difference put Buell heads on and call Andrews for their recomendation on cams. My previous neighbor did the NRHS 883-1200 with the Buell heads and Andrews cams and that thing would scream. Left my 06 1200 with with modified K&N A/C short shots and dyno tuned carb in the dust. And he had a good 50lbs of weight on me.
Old 11-05-2009, 02:18 PM
Hang Around
So my 07 1200C should have the high flow heads, are these cams any better than what I have? Can I pick up any more by doing port work on the heads, or are they pretty good stock. I'd like more power, but trying to keep to a budget.
Thanks,
Jason
Old 11-05-2009, 02:23 PM
xFreebirdx's Avatar
Quote:
Thanks,
Jason
Check this site out. Call them and ask for Dan, he can hook you up with stage 1, 2 or 3 heads. He will also let you know which is the best cam for your type of ridding.
__________________
2004 DS650X (Rotax)
1996 HD 1250 XLH
Old 11-05-2009, 06:58 PM
jag1886's Avatar
jag1886 jag1886 is offline
2007 Harley Road king
My Garage
For the 100th time, NO, unless you have head work and you ride on the red line all the time, Harley's cams just steal 5 HP from the bottom end and add it to the top end.
My bike only has head work, 10.75 compression, good ignition system, and slipons and puts 85HP to the ground using stock cams, that's almost a 100HP the way Harley measures them.
And your cams are better than mine because your bike is newer!!!
__________________
JAG1886
2007 Road King
2000 1200 Sportster
2003 1200 Sportster
Old 11-05-2009, 07:44 PM
Hang Around
Thanks for the info.
Jason
Old 11-06-2009, 08:36 AM
Nightstah Nightstah is offline
Hang Around
Just like "flatlander" said, call Andrews and tell them what you have and they will tell you whats best, ie: adding lower torque and higher top end or more lower end and less top end..
I just called them about 3 days ago and told them i wanted an even all around cam and they told me to go with the race only cams. there in the mail now, Ill let you know how they feel.
__________________
"If everything in life is headed your way, Your in the wrong lane!"
"Keep riding faster and faster until the thrill of speed overcomes the fear of death."
[2008 HD 1200 Nightster {Screamin eagle pistons, roller rocker arms, adjustiable pushrods, Screamin eagle air cleaner, Vance & Hines short shots, polished heads, cylenders bored to 90"} est 185-195 hp.
Tags
883, cams, camshafts, eagle, screamin, screaming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
