I can't give you exact numbers, but I do think its pretty significant. That is also based on a bike that weighs 200-300 lbs more. The best thing you can do is some trial and error. Just make sure you find out what the max psi is for the year shocks you have and don't go higher than that. Mine is a 09, I am 200 lbs or so, and I run mine at 14-15 psi. There are other guys on the touring forum that say they run as much as 40 psi......
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
09 Vivid Black Road King
09 HD Iron 1200
Max Recommended PSI for FLHT, FLHR/C and FLTR is 35 PSI I have run 25 totally loaded down and 2 up with no problems.. This is for 08 I have heard it increased for 09..
__________________
2008 Electra Glide Stage 1, Ness Big Sucker Vance and Hines True Duals... 2001 Sportster 883>1200 Stage 1
JayStronghawk is correct on the 08 touring shocks.
I have added some equipment to my 08 Road King and it now weighs juuuust over 900 lbs wet. I took wifey and gear from Las Vegas to Sturgis back in August. With both riders and the gear we carried we were at 412lbs total load on the bike (we weighed everything) which grossed the bike over 1300 lbs!!!
That is overloaded according to HD and the VIN plate. I ran 42psi in the shocks for best handling and it rode/handled like a champ. This was over pressure to HD standards also but after several "test" rides experimenting with different pressures this was what worked perfect for us. I also ran 2 psi over max in the rear tire.
I'm thinking about air shocks for her Sportster now but with her riding solo and no gear I doubt I'll need any air or very little in the shocks.
mowdoc
__________________ His - 08 Road King White Pearl/Pewter Pearl
King Tour Pack, Stage One with Rineharts
Mustang seat
Lots of chrome stuff Her's - 2009 883Low Sportster Vivid Black
Hd chrome engine bar, Hd detachable windshield
Mustang Vintage Solo 12.5 seat
There have been guys on here running as low as 3-5lbs psi on their Sportys.
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
I just installed a set on my bike. i tried 20psi, 15 psi, 10 psi, and 0 psi.
I been messing around for about 3 weeks and found 0 psi the best. I took the bike to Bethel NY (the site of the 1969 Woodstock Festival). It was about a 175 mile trip and i had 0 psi in the shocks, the ride was great. Now i weight about 240, so i'm no light weight. When i had 15 psi in the shocks it felt harder than the original. When i tested the shock i tried to hit every bump i could find to get a feel. I never bottomed out. The only time i might add air, is when i get the little woman on the back, but that wont be until the weather gets better. She wont ride when its cold
does it matter what year of shock or type? or are the all the same...road king electra glide etc?
The pre-09s are a little different, as mentioned. The model is the same for all the touring bikes except the Street Glide (FLHX). The rest of the tourers share the same shock.....Actually the Road King Classic may be different, but I am not sure. The difference is the FLHX shocks are about 1" shorter and valved a bit differently. Alot of folks claim they have a stiffer ride. If the Road King Classic does have a different shock than the rest, I imagine it is the same as the Street Glide's.
__________________
09 HD Iron 1200
