Alright. So just unscrew the back of the speedo housing and you will see this little metal bracket keeping the speedo in place. I just used some pliers and yanked it out then dremelled what was let on the spot holds.
Then just pull out the rubber seal on both sides. The front of the speedo just pulls out, no attachments. Rotate and reinstall the back seal. It holds everything really snug and mine has not rotated a mm. As you can see the back looks totally normal, no mods necessary.
The dummy lights have that crappy creme plastic sticking out but ill eventually make a little black box to go over it but for now it works fine.
Here's the topclamp wrenched down on the 1.5 inch risers. Nice and tight.
Most of the harness i got hidden under my tank. But ill be chopping a lot of it out in the near future and running my controls internally (they need to be shortened as well).
Still, cheap and easy mod. And a bonus is that the sun doesn't glare right off the speedo into my eyes like it did on the stock brick riser. Simple and effective. Just be sure to use some locktight! Helps a lot.
Hope this gave you an idea of what to expect. PM me if you got any other questions on the process.
