Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-19-2009, 05:08 PM
sportster2009 sportster2009 is offline
Hang Around
Default Carberator popping. Help.........
Just purchased a 2002 Sportster 1200 yesterday. Upon my fisrt ride I noticed a lot of popping thru the screamin eagle pipes. To my dismay I discovered the lack of baffles inside which is no big deal and explains the popping thru the pipes when down shifting, but I also noticed when cruising every so often the engine seems to misfire and I get a pop out of the carberator. Called the previous owner and tells me its just bad gas as the bike has been sitting for a long time and the existing gas is old. I filled the tank this morning with fresh high test and took the bike out for a several mile ride and expereienced the same thing. I think the bad gas theory is bull. Now he tells me to clean the air filter and air cleaner. I dought if that will help. Any ideas from guys out there that have had this problem or whats my next step. A little aggrevated............
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-19-2009, 05:27 PM
2003Springer's Avatar
2003Springer 2003Springer is offline
Default may want to try some octane booster!
If the guy was honest about the old gas it won't hurt. may help.
Old 10-19-2009, 05:46 PM
FandA M FandA M is offline
Probably running too lean..........richen up your mixture.Also check for air leaks at the intake
Old 10-19-2009, 05:58 PM
Hang Around
Might have to take it to our local Harley dealer to have diagnosed. Break out the big piggy bank. ( Wow is me)
Old 10-19-2009, 06:39 PM
jag1886's Avatar
jag1886 jag1886 is offline
2007 Harley Road king
My Garage
Quote:
You have a set of straight pipes in the bike and that will make it run like bad. Change the gas but it's still going to run like crap until you find a set of old baffles or switch out the slipons for a new set. I think you can buy a new set of baffles from Cycle Shack that will slip right in.
__________________
JAG1886
2007 Road King
2000 1200 Sportster
2003 1200 Sportster
Old 10-19-2009, 07:16 PM
Hang Around
I have screamin eagle pipes, not stock slip ons but the guy is sending me some baffles for them. I think it will stop the pooping during deceleration, but how about the miss and pooping thru the carberator. Will baffles help that?
Old 10-20-2009, 02:22 AM
bigmikea69 bigmikea69 is offline
Hang Around
hey guys , i dont have a sportster but im working on 1 right now and they are very similar to my softeail as far as carb set up with very little differences . first if the pipes arent stock the carberator needs to have a jet kit installed or it will never run correctly . 2nd if the bike has been sitting for a long time and the gas was left in the carb , take the carb apart and look at the diaphram !! my softail sat for a year and a half and wasnt running correctly , the harley dealers included told me it was BAD GAS !!! nope !! it was the diaphram !! take the carb apart and buy a KEIN kit , they are very simple to install and come with a sheet that asks questions about the bike , like aftermarket exhoust ect... then you just match the info to the correct jet size and walla !!!!! good luck hope it works out ..
Old 10-20-2009, 07:15 AM
guitarman023 guitarman023 is offline
Send a message via AIM to guitarman023 Send a message via Yahoo to guitarman023
yup, take the bowl off the carb, spray carb cleaner on anything that isn't rubber, put it all back together, ride it, then put new plugs in it, ride it, adjust timing, ride it. That's the best way to trouble shoot it, try one thing, and take it out for a ride.
__________________
If you can't be good, be good at it!
Old 10-20-2009, 07:24 AM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
Prospect
sounds like its too lean on the bottom end,bike was most likley jetted with baffles,took them out,now its too lean,see what int jet youve got,go up 1 size
kirby
vee twin performance.com
Old 10-20-2009, 07:30 AM
1200efi 1200efi is offline
Senior Rider
Lightbulb
If the bike was sitting that long with "bad" gas, a little sea foam (great stuff) wouldn't hurt it at all. Ride safe.
Tags
03, 1200, carberator, carburetor, cleanning, davidson, gas, harley, king, misfire, missing, old, popping, road, shovelhead, sportster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
