Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-08-2009, 03:29 PM
anubisss's Avatar
anubisss anubisss is offline
2002 Harley Davidson FLSTFI
Default Randomly flickering brake light problem...
So I thought I had fixed this problem by removing the run turn brake module but I was wrong. The brake light will randomly flicker at all different times. the rear brake pedal lever is a bit loose due to several light drops by the wife and I am thinking maybe when she hit s a big bump it shakes the whole assembly enough to activate the rear brake light switch. I am not sure how to tighten this up as it is not jsut the lever, but the foot peg bracket as well. All bolts are nice and snug, or at least look that way from a visual inspection.
The brake light switch works fine and running light on the brake light works fine as well. Bike is a 2005 883L.
First things to check? A good way to snug up the whole rear brake pedal assembly? Please let me know. TIA.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-08-2009, 04:26 PM
3rdgear's Avatar
3rdgear 3rdgear is offline
Senior Rider
Send a message via Yahoo to 3rdgear
This may be a long shot but it sounds like you might have a wire that is rubbing somewhere causing connection issues..
and if thats the case you may want to find it before you loose the light all together..
__________________
95th Anniversary XL 1200 Custom - 1040/3000
Stage 1 Upgrade
SE II Exhaust
"Don't drink and park accidents cause people"
Old 10-08-2009, 09:39 PM
wings-n-strings wings-n-strings is offline
Hang Around
I had the same problem with my wifes 07, 1200 Sporty. Did the same thing you did (removed Turn/Run/Brake module, checked everything in the wiring circuit) and could not find the problem. Finally figured it out. I had installed leather fringe tassles on the brake and clutch levers and while driving the wind was pulling the tassles enough to make the brake light flutter! Do you have Leather fringe tassles on the levers?
Old 10-08-2009, 09:41 PM
anubisss's Avatar
No fringe. Maybe the front lever is just a bit loose. After working on her bike this morning I spent the afternoon washing mine. She'll have to wait until tomorrow.
Old 10-15-2009, 02:41 PM
kevmic28's Avatar
kevmic28 kevmic28 is offline
Prospect
Mine does the same thing occasionally turned out the light assembly was loose. CHeck yours, mine would vibrate and loose the ground connection to the fender.
Old 10-15-2009, 05:23 PM
WRAITH's Avatar
WRAITH WRAITH is offline
I have the same problem. Check the front break switch, move the break leaver up and down. Does the light flicker when you do this? The break lever and or front switch may be worn.
__________________
I am a Rider, not just an owner.
Old 10-15-2009, 06:37 PM
congo_usmc's Avatar
congo_usmc congo_usmc is offline
Senior Rider
if you recently removed the front brake lever you could have dammaged the front brake switch when you put it back on. this has happened to a few guys including myself
__________________
'05 1200 Custom
V&H Shortshots
SE Stage 1 Intake
12" Mini Apes
http://viewmorepics.myspace.com/inde...f8IPXPshDK0%3d
Tags
brake, davidson, flickering, flickers, front, harley, indicating, light, problem, problems, randomly, rear, stop, switch, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
