Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-30-2009, 03:27 AM
lbfam730 lbfam730 is offline
Hang Around
Default Road King shocks installation
Hey all. After reading few posts about RK shocks i've went ahead and purchases a set. i will be installing them tomorrow on my iron and i was wondering, would i have to put the bike on the lift? i know that the RK shocks are longer than my stock shocks and figured that i'd have to take it to a shop to use the lift since i don't have one but before doing that i just wanted to make sure from the people that actually done the installation. also, would i need washers even though i don't have belt guards? i hope this isn't too dumb of a question, thanks all.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2009 H-D Iron // Support the Troops!
Last edited by lbfam730; 09-30-2009 at 03:29 AM. Reason: forgot to add something else.
Old 09-30-2009, 08:06 AM
fox4's Avatar
fox4 fox4 is offline
Prospect
Yes since they are longer it would be easiest to use a jack to gain the extra clearance needed. I don't think you would want someone to pick up the back of the bike and hold it while you bolt them up. I don't even know if that would be possible. Bike jacks can be found for pretty cheap if you go to a place like harbor freight.
__________________
-)-Joe-(-
'08 Nightster w/ wrinkle black drag bars, SE a/c, black V&H Sideshots, V&H Fuelpak, Home Depot 2" tank raise, Home Depot coil & ignition relocation, and Cheap leather throw over saddle bags when needed.
Old 09-30-2009, 08:36 AM
dlhike's Avatar
dlhike dlhike is offline
Hang Around
Default rk shocks...
did mine in driveway - no lift - do one side at a time...have someone there to lift back of bike - start by putting top bolt in then lift rear end and get bottom bolt started in hole no need to hold while tightening bolt...
A jack would make things easier if available - I didn't have access to one
You will need washers as RK shock is larger in diameter than regular sporty shock - you may be able to get by with 2 instead of 3 since no belt gaurd...
My experience only here - so if I got something wrong it's generally cause I do things the hard way...then figure it out afterwards
__________________
07 XL1200R
U.S.M.C 79 - 82
Ride what U want, where U want, how U want and wear what U want while doin it...if they can't take a joke - kill em...
Old 09-30-2009, 07:35 PM
Austen's Avatar
Austen Austen is offline
Send a message via AIM to Austen
as they said, its better to use a lift. prolly find a decent one for 100 bucks.
its real easy to swap them out. have fun. u might want to buy lowering blocks cuz the rk shocks are 13 inch. unless ur ok with that
__________________
Live The Dream
Old 09-30-2009, 08:16 PM
SPECIAL ED's Avatar
SPECIAL ED SPECIAL ED is offline
That's exactly what I did and I have a lift.It just seemed easier for me to hold up the rear of the bike while my wife lined up the shocks ad bolted them up.I suppose I could do it by myself with a lift but I think it would take longer.Oh, and I've done this three times now with taller, shorter and even shorter shocks for my Dyna.
__________________
WORLDS MOST EXPENSIVE RAT BIKE
Old 09-30-2009, 08:31 PM
Austen's Avatar
to each his own, i believe in working smart not hard. a lift is def easier.
__________________
Live The Dream
Old 09-30-2009, 10:57 PM
Hang Around
Thanks for all the input guys. I went to harbor freight and purchased a lift for $66 and tackled the job today. i thought it would be piece of cake but it took way longer than i thought. when i brought the lift home it was a bit high so i had to figure out a way to get the bike on the lift so i can jack it up. i got few pieces of wood and pushed the rear wheel on it then got more wood and placed them in front of the front wheel and pushed it forward so now both wheels were on the wood so i can slide the lift under. it would've been so much easier if there was someone around but since it was just me it took a lot of sweating to get it done. i had to slide the lift by stepping on the lift and sliding it underneath. then i jacket it up while holding the bike upright. plus to line up the shocks, i had to lift the back fender while trying to keep the bike from tipping and to line up the bolts to the holes. i thought this would be a cake but to be honest it was a pain in the ass... but so worth it in the end. i used 4 washers in each side, 2 top/2 bottom and dropped the bike almost to get the stock height since RK shocks are long as hell. took it for a spin and look for few bumps to test it out and i'm very pleased with the result. again, thanks for the advise and i'll post some pics soon.
__________________
Old 09-30-2009, 11:39 PM
Austen's Avatar
good job, that was a major consideration for my lift, lowest profile as possible. plus it helps to tie the bike down so it doesnt tip over. post some pics
__________________
Live The Dream
Tags
2009, davidson, eagle, harley, king, motorcycle, oil, rebuild, road, roadking, screamin, setting, shock, shocks, sportster, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
