Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-20-2009, 07:37 PM
K3JN K3JN is offline
Hang Around
Default 2003 sportster 1200 custom won't start
One day i decided to start the bike and at the end of the battery it backfired out the pipes. We found the plugs were blackened so installed new plugs. It started right up. After sitting a few weeks went to start it up again and same thing backfiring out the pipes. After drilling out the timing cover and turning the module contained therein; it started. On the road it runs good and strong. No probs. But, when you shut it off it's the same thing again ....no start...............then if you play with the setting of the module it seems to start again. What's up with this? It has like 8k miles....
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-22-2009, 02:57 PM
mjmangus mjmangus is offline
Senior Rider
By turning that module you're changing the timing. You might want to check the wiring harness for damage or check the connector. Everytime you move the module you're pushing and pulling on the wires. Are you shutting the fuel off when it sits? You may need a battery tender if you don't ride it that much.
__________________
2007 Softail Custom
2005 Road King Classic
1991 CHP FXRP
1942 WLA (Civilianized)
Old 09-22-2009, 09:41 PM
Hang Around
Hello and thanks for the input. We checked the connector under the frame today thinking a poor contact. We are thinking it's an intermittent module...$ 255.00 + tax........... what a price huh?
Old 09-22-2009, 09:44 PM
Hang Around
Default 03 Sporty
I read you should shut off the gas supply in case of failure; to put the gas in the oil. I have never shut off the gas in any b4. Maybe I should start now? Thanks Joe
Old 09-23-2009, 08:01 AM
WVHogRider's Avatar
WVHogRider WVHogRider is offline
We really don't have enough info to point you in a direction for a fix.....Does the bike have the Stage 1 done? It could just be that the jetting is wrong causing the fouled plugs. Who's telling you it's the timing? If you're not shutting off the gas, the carb could be gunked up messing with the jets which could foul the plugs. It could be a number of things, but we need more info before pointing at one thing like timing. Have you checked for any codes?
__________________
http://www.hdforums.com/forum/image.php?type=sigpic&userid=20830&dateline=121812  6494
Old 09-23-2009, 12:27 PM
Senior Rider
The 03 is basically an EVO and wont display any trouble codes.
__________________
2007 Softail Custom
1991 CHP FXRP
Old 09-23-2009, 03:02 PM
WVHogRider's Avatar
Yes it will......, just as my '00 will.
http://www.sportster.org/tech/evo-te...edo-diag.shtml
__________________
Old 09-23-2009, 10:02 PM
Hang Around
Thanks People for the concern. Today I started turning off the gas, but it seems as though it was timing; this is why we decided to make movements in the timing module which then it did start. Yesterday we pulled apart the timing/cam module under the frame and disconnected and connected ( many times then sprayed with WD 40 ) also we soldered the cable from the battery to the starter; heard that could starve the iggy. Well, tried to start bike today about 3 or 4 times and it started every time , so we will keep close watch from this point on ! Should it fail to start I am gg to try to put a heat gun on the module to see if that does anything. I appreciate the inputs Joe
Old 09-23-2009, 10:03 PM
Hang Around
I will yhave to RTFM to see how to read puter if there's one there
Old 09-23-2009, 10:04 PM
Hang Around
YES it has Stage one Update !
Tags
1200, 2003, 883, custom, davidson, good, harley, ignition, jump, setting, sporter, sportster, start, starting, timing, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
