Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-05-2009, 10:01 PM
spartan95 spartan95 is offline
Hang Around
Default Choke off = Stall
Looking for help with an 03 1200 Sportster. After a several month storage period, the bike will not stay running once the choke is pushed in after a significant warm up period. Any suggestions? Thanks in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-05-2009, 10:13 PM
midnight2005's Avatar
midnight2005 midnight2005 is offline
can not diagnose it on here, but you are getting way too much air. check for air leaks, spray carb cleaner around the carbs when it is running, when it hits the leak it will rev up. The only other thing it could be is not enough gas, I have run short on gas and pulled the choke out to make it another mile on fumes to a station. just check for leaks and make sure all lines and the carb is clean and allowing enough gas to get in
__________________
Old 08-05-2009, 10:21 PM
drum412 drum412 is offline
Looks like you may wanna clean the carb out.....A basic cleaning will probly surfice, just pull the jets out and clean them. Another option that sometimes works with minor varnishing of the jets is to run some seafoam fuel treatment through your tank, and you may be able to get by without physically having to clean the carb. Also like midnight2005 said, it could also be from an air leak, but because your having problems after storage I'd be leaning more from fuel varnishing as being the culprit. The other thing is, do you have fresh gas in the bike?? if not get some fresh gas and see if that helps.
__________________
94' 1250 Hugger
stretched tank
andrews n4 cams
cycle shack slip-ons
mustang vintage solo
Mikuni HSR42
Old 08-05-2009, 10:27 PM
ChoppedNbobbeD's Avatar
ChoppedNbobbeD ChoppedNbobbeD is offline
Prospect
1996 HARLEY DAVIDSON SPORTSTER
when you hit the throttle if you hear kindof sucking noise. keep reving throttle, if you fell air pushing out around your push rods or heads, you have a bad head gasket, sort of common with sporty's. and definetly clean the carb out. if in doubt, support your local mechanic
__________________
"IF IT AIN'T BROKE, THEN CHOP IT UP TO FIX IT"
Its a copper colored Vespa Moped, hope I'm still allowed to post here!?!
Old 08-05-2009, 10:28 PM
Prospect
oh, and dont even think about trying to ride it and keep it running by throttleing it. you will cause more headaches. tow it to the mechanic. good luck.
__________________
Old 08-06-2009, 07:14 AM
xFreebirdx's Avatar
xFreebirdx xFreebirdx is offline
Run some SeaFoam through it.
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
1996 HD 1250 XLH
Tags
air, choke, closed, forum, harley, hd, moped, motorcycle, noises, on, position, pushed, run, runs, speeds, stall, sucking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
