Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-24-2009, 06:29 AM
flyingsportster flyingsportster is offline
Hang Around
Default please help 1200 sportster runs bad
I have an 05 1200 carberated sportster with the screamin eagle kit.
heres the symptoms:
1 Does not require choke to start up.
2. Runs like it is choked
3. Runs great under acceleration but not at cruising speed
4. Spark plugs are very black and suite, so is inside tip of my exhuast
5. does not use any oil
6. gas mileage has gone to hell
7. Back fires through the carb
I have pulled the carb off the bike, and cleaned up the choke and inside where the diaphrame is on the carb. Put it all back together and still no change.
Any help or suggestiions would be greatly appritiated and thanks in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-24-2009, 06:39 AM
MaroSteve's Avatar
MaroSteve MaroSteve is offline
Prospect
Send a message via AIM to MaroSteve
hmm. sounds like your running rich man. I would check basics. Plug wires & distributer (although those dont really fit in to the great under accel part). But Check them any way. Continue with your tuning screws on the carb, they may have been messed with.
__________________
Steve
2010 Harley Nighster: Soon to be Mine
http://hdforums.com/forum/image.php?type=sigpic&userid=99896&dateline=124802  9435
Quote:
Originally Posted by Madmurph View Post
But i felt like a real tool. Lesson learned i WILL NEVER not wear full ridding gear ever, I dont care how hot probably saved my ass.
Old 07-24-2009, 06:50 AM
moosh's Avatar
moosh moosh is offline
Senior Rider
floats stuck?
__________________
trouble with Italian food ? ..... 3 days later your hungry again
Old 07-24-2009, 08:17 AM
xFreebirdx's Avatar
xFreebirdx xFreebirdx is offline
What mods with the Screaming Eagle kit?
Did you mod it or buy it that way?
What jetting does it have in it now?
Is the Air/Fuel screw already exposed?
How does it run or start with the air cleaner cover and filter removed?
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
1996 HD 1250 XLH
Old 07-24-2009, 12:30 PM
Hang Around
the bike will idle like it should with air cleaner off or on.
I have not rode it with the air cleaner off.
The only time my bike will run poor is at cruising speed weather its at 30mph or at 75mph.
I bought the bike with 230 miles on it from a guy that had the mods done.
I know it has new pipes and has been rejeted. what I believe is the stage one kit.
I know the bike is running rich, and i have adjust my air/fuel mix screw and it does not seem to make a difference.
By the way guys here is one more problem if i havent mentioned it before.
I do not have to use the choke to start the bike when it is cold. I hear that the 1200 should need choke to start and run.
thanks for all your input so far, the bike is at the shop since yesterday, but when i called even they didnt know what was wrong with it.
Old 07-24-2009, 12:42 PM
MaroSteve's Avatar
Prospect
yea sounds like some pro's need to look at it. thats some messed up shit.
Im thinking something on the inside screwed up.
__________________
Steve
Old 07-24-2009, 12:43 PM
vincentostapowich's Avatar
vincentostapowich vincentostapowich is offline
Prospect
Check the obvious.
runs like crap at idle,,doesnt need fuel.
Either the pilot is too rich or it isnt in at all and is sitting in the bottom og the fuel bowl,or the person forgot to put it in.
Check floats,check needle and seat,,check most importantly petcock diaphragm.
Old 07-24-2009, 12:54 PM
cHarley's Avatar
cHarley cHarley is online now
1950 Schwinn Super Sport
+1 on the pilot jet being way too big or missing. With the standard SE package (exhaust & A/C), the pilot jet shouldn't need to be any larger than a #45.
__________________
IF YOU CAN'T RIDE IT OR TAKE IT TO BED, IT AIN'T WORTH HAVING
Light travels faster than sound. This is why some people appear bright until you hear them speak.
Old 07-24-2009, 12:57 PM
JayStronghawk's Avatar
JayStronghawk JayStronghawk is offline
2007 Chevrolet Silverado
Send a message via AIM to JayStronghawk Send a message via Yahoo to JayStronghawk
Agreeing with Charley He knows his Sportsters ... Has bailed me out of trouble more than once when comes Sporty's
__________________
2008 Electra Glide Stage 1, Ness Big Sucker Vance and Hines True Duals... 2001 Sportster 883>1200 Stage 1
Old 07-24-2009, 04:55 PM
jag1886's Avatar
jag1886 jag1886 is offline
2007 Harley Road king
My Garage
You should also check the enrichener cable and valve if they been apart and not put back together right or of it's stuck that can cause your problems.
It is also almost 5 years old and if it sat around with the same gas in it for a few years, you may need to pull the carb and really rebuild it, not just squirt it with some carb cleaner, a build up of varnish in the wrong spot can cause all forms of problems.
__________________
JAG1886
2007 Road King
2000 1200 Sportster
2003 1200 Sportster
Tags
1200, 2009, 2773104, bad, carb, davidson, fuel, harley, hd, jet, main, problems, run, sportster, stock, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
