Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-24-2009, 06:50 PM
flyingsportster flyingsportster is offline
Hang Around
Okay guys, Harley called me back they think the carb has a crack in it somewhere.
Ive never heard of this before, have any of you?
I think Im just going to pull the carb apart myself and do a full rebuild on it.
Thanks guys your input has been awesome.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-24-2009, 11:47 PM
drum412 drum412 is offline
So did they tell exactly what they did..........if all they tell you(it's got a crack somewhere), i hope they don't charge ya for it. But yeah just rebuild it, it's pretty easy, and you may wanna pick up a new main and pilot jet, a 45 and 180 is a good start.....just to make sure the former owner didn't oversize the original jets by drilling them, jets are only a few bucks so. Also check the jet needle to see if anyone put shims/washers on it, and if so take them out and start fresh. Check all the gaskets and replace if needed. Also when dissassembled, get a gallon of good carb cleaner to soak the carb in, then after a good soak, use gumout carb spray to rinse it, and also shoot it through every orifice hole you find, followed up by a flash dry with compressesed air. Put it back together.....double check the float level is correct....too high and you'll run very rich, which could have been the problem to begin with so take the time to do it right. And keep us posted if you find out what the problem is........sooner or later someone else will be on board here looking for the same solution.
__________________
94' 1250 Hugger
stretched tank
andrews n4 cams
cycle shack slip-ons
mustang vintage solo
Mikuni HSR42
Old 07-24-2009, 11:58 PM
1931jamesw's Avatar
1931jamesw 1931jamesw is offline
sounds like the pilot jet
__________________
Old 07-25-2009, 12:40 AM
Hang Around
ok heres the notes from harley.
Plugs badly fowled upon arrival
Stage 1 installed. slow 45 main 175 needle 65a slide vent 1/8
found fuel screw @ 1/4 turn. Bike ran and started w/ not enrichment.
adj float height .433
bike still ran with zero enrichment w/ fuel screw at zero.
changed enrich plunger. same result as above.
plugged enrich jet in bowl, bike still ran recomend new carb. Fuel is by passing appropriate passages. possible fuel screw seated to tightly, deforming seat.
Thats everything they found out, costing me a grand total of $229.38.
So anyone have any suggestions?
Or where i can get all the specs and settings on the carb?
thanks for all your input on my problem.
Old 07-25-2009, 01:19 AM
Well do a rebuild and check things out yourself first....... The thing is with the mixture screw......it'll have little to no effect at anything above 1/8 throttle.......if you want proof of this, take a good running bike and fully seat or even remove the mixture screw and the bike will run just fine as long as it has a little throttle.....but will die when back at idle.....this is just to prove that the mixture screw isn't necessarily your problem unless it did in fact relate to cracking the carb near the seat. So all i'd reccomend is give the carb a rebuild and keep a sharp eye out for any physical damage, and like I said earlier, pay close attention to all the gaskets, including the accellerator pump diaphram. But from there, i'd probly keep an eye on ebay for a new carb......i see used keihins often sell for $40-50. Or if you can't find one, i have my old keihin still in exellent shape, Its from a 94, but as far as I know it's the same carb with no changes over the years, although you'd have to double check that, but if you were interested I'd sell mine for $30 +shipping.
__________________
94' 1250 Hugger
stretched tank
andrews n4 cams
Mikuni HSR42
Old 07-25-2009, 03:32 AM
Hang Around
I may be very intrested in getting your carb from ya. I called up to our local bent bike dealer and they didnt have any.
if you want you can email me at cobizle@hotmail.com
I turned my fuel selecter valve to the almost off position to see if that would help restrict the amount of fuel being delivered. it seem to help just a bit but really hard to tell.
all the more info would be appriciated.
oh and is there a website I can visit that will point out all the different parts of my carb, so that i dont get them all mixed up.
Thanks again in advance.
And how come these bikes dont have fuel filters?
Old 07-25-2009, 12:12 PM
Hang Around
Do you happen to have a part number for that carb?
Old 07-26-2009, 01:02 AM
Unfortunately I don't know what the part number of the carb is, you'll probly have to check with the dealer and have them look it up and compare part numbers. I tried to look for info online on the carb, but details were a bit sketchy. I'm out of town right now, so I'll dig the carb out on Monday, and see if I can find any more info for you on it then. I may also be able to scan a picture of the carb parts diagram from my hd-manual then also.
__________________
94' 1250 Hugger
stretched tank
andrews n4 cams
Mikuni HSR42
Old 07-26-2009, 02:00 AM
Hang Around
Just want to say thanks you have been most helpfull.
Old 07-26-2009, 03:57 AM
cHarley's Avatar
cHarley cHarley is offline
1950 Schwinn Super Sport
The p/n for an 04up 1200 Carb is 27731-04 except for CA which is 27732-04.
__________________
IF YOU CAN'T RIDE IT OR TAKE IT TO BED, IT AIN'T WORTH HAVING
Light travels faster than sound. This is why some people appear bright until you hear them speak.
Tags
1200, 2009, 2773104, bad, carb, davidson, fuel, harley, hd, jet, main, problems, run, sportster, stock, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
