Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 06-15-2009, 11:45 AM
docdizzle docdizzle is offline
Hang Around
Default Rejetting
Ok, so one of the 1stSgt's at my battalion has told me that he will help me rejet my Sportster (and looked at me like I was retarded when I asked "You know how to do it?"), and I was wondering what size should I get? My bike came with 1 3/4" Cycle Shack drag pipes, but the previous owner kept the stock breather and jets. Also, what would you guys recommend for a high flow breather? I was thinking of just getting the Screamin' Eagle. Thanks in advance!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 06-15-2009, 12:30 PM
xFreebirdx's Avatar
xFreebirdx xFreebirdx is offline
Hint: some information about your bike would make this easier.
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
1996 HD 1250 XLH
Old 06-15-2009, 12:57 PM
Hang Around
Hah, my bad. It's an 06 1200 Custom, only mods so far are the pipes that came on it and Progressive shocks (lowered, handy for my short ass at 5'6). Does the DynoJet kit come with multiple sizes? And would I be just as happy with K&N over the Screamin' Eagle?
Old 06-15-2009, 01:12 PM
Krakanator's Avatar
Krakanator Krakanator is offline
Prospect
I would advise against the Dynojet kit. If I remember correctly they are like $80, when all you really need are the jets, which are a couple bucks a pop. As far as which sizes to use, Im not sure about the 1200, but if you were to search around to forums I am sure you will find the recommended sizes, that is what I did. One more thing, someone the SE kit will either confirm this or blow it up, but I'm pretty sure the K and N filter element is made for the SE backplate, that way youre in 130 for the SE setup, but you would still need to get the K and N element.
__________________
2002 883R
Screamin' Eagle Pro 2-1 exhaust
Doherty PowerPacc w/ Power Vents
Old 06-15-2009, 01:22 PM
CURTYS06FLHX CURTYS06FLHX is offline
Hang Around
Its probably to lean with stock jet with drag pipes see what jet is in it go bigger from there. the k&n will lean it out even more
Old 06-15-2009, 01:23 PM
Hang Around
Ok, the Harley shop guy recommended doing a high flow air kit along with the jets. What are the actual parts that I would need, just the jets themselves? I am really not a mechanical person at all.
Old 06-15-2009, 01:24 PM
95yj 95yj is offline
Hang Around
The dynojet kit comes with stuff you won't use, the Thunder Nozzle, etc. and doesn't come with the low speed jets. It also replaces the spring on the piston slide with a weaker spring to help open faster. It will come with a 160, 170, 180 and 190 main jet. Instructions say 160 for stock 170 for new air cleaner or exhaust 180 for both and 190 for internal mods. Obviously these are just a starting points.
You'll probably want to change out your low speed jet also. I believe the 1200 comes stock with a 45, you probably want a 46 or a 47. Buy both and see which one is best. Save the 45 and give it to someone with an 883 since that's the one they probably want to upgrade to. The only place I've seen the low speed jets for sale individually is J&P.
Old 06-15-2009, 01:30 PM
Hang Around
Trial and error with jetting
Old 06-15-2009, 02:08 PM
SpoilSport's Avatar
SpoilSport SpoilSport is offline
Prospect
I had my Stage 1 done at the local dealer at 3,000 miles. The stock jets were #42 Slow and #180 Main. The dealer changed the Slow to a #48 and the Main to a #190. The Jet needle was also changed to the NOKH. I purchased the CVH Jet Kit XL Series by Keihin, makers of the HD carb, from the dealer for $39.00 (still have all the original and unused jets and needle laying around).
I went to the dealer for warranty purposes. I would definately go to an indy shop if I were to do it again. The cost would probably be about half of a Harley shop, and they are more lenient when it comes to parts that are really needed ... and not just making a sale.
Mileage now is anywhere from 44 (cooler temps) to 48 MPG (warmer temps) depending on weather conditions ... not much difference from stock. I never did get the claimed 52 MPG even when the bike was new.
__________________
http://hdforums.com/forum//spoilsport-albums-spoil-sportster-picture57892-hdf1.jpg?s=41a0b37d3324b3da08b9afa57b407850
'06 XL1200C, Stage 1, V&H Short Shots, Kuryakyn Corsair A/C
Old 06-15-2009, 04:10 PM
Hitechluddite Hitechluddite is offline
My DS "No hassle jet kit costs $33 at the local HD dealer and includes a needle, which I wouldn't mess with. 2 low speed jets, 2 high speed jets and recomendations on what jet to use for your stage of mods. I would also recommend a E.Z. adjust Idle jet needle. It cost about $20 and lets you easily adjust your idle mixture with everything assembled.
I like my S.E. aircleaner, haven't looked into a K&N element for it yet.
Tell your first shirt to lighten up, I may have been his boss when he was a broke d$^^ private!!! LOL
__________________
Any wimp can put 100k on a Ultra, it takes a real man to put 100k on a 883 Sportster!
Cold Warriors on Hogs in Japan!
Tags
06, 1200, 2002, 883, custom, davidson, harley, jet, kit, main, recomended, rejet, rejetting, sportster, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
