I have an issue with my fuel shutoff on my 03 sporty. when I turn the fuel on I get a drip out of what I think must be an overflow or something coming right out of the bottom of the shutoff it's self. I have let it sit for a while (2 months)but I've started it about once every two weeks. My battery went dead and I might have flooded it before I put in the new one but I ran it down the street for about 5-10 minutes and still drips.
Thanx for any help.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
More than likely your float is sticking. It's in the bowl of the carb. First of all, if it's got gas from last year in it, drain it. Second, get some seafoam and a new tank of gas. The best way to clean out the fuel bowl and get the float unstuck is take the bowl off the carb and spray everything, but the rubber gasket, down with carb cleaner, and check the condition of the float needle. Make sure the rubber on top of the needle is in good shape, no cracks, or rings around it. Before removing the bowl though, try tapping on the side of the fuel bowl with the new gas on, and see what happens. Until you have time to mess with it, you can run it with your gas about a 1/4 of the way on, and it might not leak
__________________ If you can't be good, be good at it!
+1
__________________
2004 DS650X (Rotax)
800 Open Mod (Rotax)
617 Mach1 on NOS (Rotax)
1996 D3500 V10 425hp
1996 HD 1250 XLH "Custom" Stage 2 Heads, SE.497 Cams, SE Prog. Race Ignition.
Vet: US ARMY 78 - 81.......Patriot Guard Rider#45266
2004 DS650X (Rotax)
I had that problem on my 02 and had to replace the fuel valve. It dripped for a few min. after the bike was shut off, replaced valve $30 from the stealer. No more problems....
__________________
No matter where you are, you can always say "I am Here."
If the float was sticking it would be coming out of the overflow on the carb, not the petcock.
__________________
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. - Thomas Jefferson
Yeah, I just re-read the problem. Mine doesn't have an overflow for the petcock. lol
The hole he is refering to is the vent hole for the diaphram, the diaphram probably has a hole in it and will need replaced. The bike is probably runnng a little rich because it is sucking gas through the vacuum line also.
__________________
