Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 06-08-2006, 06:50 PM
tim@tmgdesigns tim@tmgdesigns is offline
Hang Around
Default RE: how do I get it to stop backfiring thru the carb?
The enrichment screw is only an idle adjustment. If you look at the pic above that someone included it will help you make the changes yourself. It really is very simple. Change to a 45 or 48 slow jet, and a 170 main. This should correct your problem. The jets just screw in. Dealerships dont make any money on warrentee work so sometimes they are reluctant to be aggressive in getting to it. The jets are availible fgrom the dealer for about $5.
Goodluck,
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Tim
Not all who wander are lost. (Tolkien)
Old 06-08-2006, 10:07 PM
Elwood77 Elwood77 is offline
Hang Around
I tryed real hard to get my dealer to fix the same problem... then leaving my HOG meeting the other day it farted and stalled as I was slow speed turning and I dumped it into a curb.
So make sure you fix it.. what started as a hassle for me became a big headache now[:@]
Old 06-08-2006, 11:08 PM
spikehyre spikehyre is offline
Seems like a common problem for everyone, including me. In this forum you will find everyone who has tackeled this pulling the plug on the bottom of the carb and then screwing in the slow jet to seat (be gentle) and then backing out up to 2 turns depending on what else you have done to the bike, like pipes and jetting. The purpose of seating the jet is to get a starting point for your adjustment. You cannot see the screw while the carb is on the bike but you can adjust it onced the plug is removed. My dealer also blew smoke up you know where but I am starting to recognize the sensation. Bought a service manual and it walked me through the process. I felt better about doing it myself and learned a bit more about the bike in the process.
__________________
07 FLSTN
Just chrome.
Old 06-09-2006, 01:46 AM
04XL1200C 04XL1200C is offline
Senior Rider
Could it be that your gas is lower than 91 octane. My '04 1200 will carb fart if I use 87 octane fuel. Gas mileage suffers greatly also if I use cheap 87 octane gas. I only use Sunoco Ultra 94.
Old 06-09-2006, 02:02 AM
dg7080 dg7080 is offline
Prospect
Well, I adjusted the idle mix jet counter-clockwise as much as 1.5 turns from my starting point, then even played with it the other direction about a full turn. Still got the farts no matter where I set it. Its a random thing when riding, but I can reproduce easily if I try when its at idle and I rev it quickly. Really sucks.. The dealer jetted this thing, so they ought to be able to get it right. I'll probably call them tomorrow and take them a print out of this thread if I can make it over there.
__________________
'07 FXSTC
Old 01-11-2007, 11:29 PM
viperbob94 viperbob94 is offline
I have a 6 month old 1200C also. It had the same symptoms as you're describing & also had a high-speed hesitation. The dealer replaced the intake & carb seals. Haven't riden much since then, but it seems to have fixed it. Maybe you can tell you lame dealer. I have it fixed at Orange County HD in Irvine, CA. Good luck.
Old 01-12-2007, 12:56 AM
LAZYBOY LAZYBOY is offline
Senior Rider
stage 1 solved all of my carb farts. only does it now if i shift too soon. just rejetting and adjusting the mixture works great for a cheap fix. since the bike is so lean you get a bigimprovement for about $100.00
__________________
2006 XL1200c
black cherry/black pearl
Cycle Shack baloney cuts
Kuryakyn Twin Velocity a/c
carb drilled and re jetted
Milwaukee Twins sissy bar
Mustang solo seat & fender bib
Saddlemen slant bags (sometimes)
Kurakyn Iso-Grips w/Throttle bo
Old 01-12-2007, 01:20 AM
diablo666 diablo666 is offline
If your bike is an 06 you already have a 175 main jet on an 883.You would need to bump it up to a 180.The slow jet should be between a 45 and a 48 depending on location.Harley changed the needles so a bigger main jet was used.if you go in to change the main make sure you hold the tube it's in so I don't have to tell you how the other jet goes in.Make sure you replace the bowl screws with allen head screws.They are metric and I forget the size so take an old one with you.I got mine at a hardware store in stainless steel for under a buck each.There are 4 carb bowl screws.After you have the allens installed you can rejet as needed without even removing the air cleaner housing.Make sure you use a very good fitting phillps when you go to take out the carb bowl screws or they will strip out on you.
Old 01-12-2007, 02:19 AM
Scuba Steve's Avatar
Scuba Steve Scuba Steve is offline
Hang Around
This same thing happens on my '06 1200C. I purchased a rejet kit off ebay for about 15 bucks including replacement bowl screws. I haven't installed them yet, as I won't be able to ride for a few months yet. My question is, Will rejetting this thing myself void the warranty? It has a year and a half left, so I don't want to lose this by tinkering. Also, how much does this affect fuel economy? I beleive the kit is 46 Pilot and 180 Main.
Old 01-12-2007, 02:28 AM
1200cc 1200cc is offline
Senior Rider
my 2003 1200cc custom is killing me,,LOL
im glad to here it happens on new bikes as well
something has to be done on mine also..
its a cougher,,spitter what-ever
__________________
.2005 1200R Sportster
stage1 Screamin-Eagle Air cleaner
Vance&Hines Pipes,
Blue-White
Tags
1200, back, backfire, backfiring, carb, carburator, davidson, evo, firing, fix, harley, harleys, hd, problems, sportster, stop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
