Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-06-2007, 04:54 PM
tatersalad tatersalad is offline
Prospect
My Garage
Default Using a lift on a sofetail
Anyone have any difficulties using a lift when raising your sofetail? Seems MoCO sells a device to cover the lift arms to protect the softails under belly.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
potato...potato...patato...
Old 03-06-2007, 05:00 PM
hdpearson13 hdpearson13 is offline
My Garage
Default RE: Using a lift on a sofetail
just put mine back up for storage i just slide it cross bar and tie the front down for balance
__________________
05 Standard 83 ironhead future FXR owner
OneBlackFly OneBlackFly is offline
My Garage
Yes, get the frame protectors. They are orange semi-hard plastic and cushion the frame to allow the shocks to clear the lift. About $15 and well worth it. See this link: http://www.harley-davidson.com/gma/g...bmLocale=en_US
__________________
... Paul ...
Old 03-06-2007, 05:01 PM
anubisss's Avatar
anubisss anubisss is offline
My Garage
Never needed anything but my lift. Here is how I do it. I slide the lift under from the rght side (the side you fill the oil on). If it hits a point where it will not roll under the bike any further I grab the right handgrip AND THE BRAKE. I pull the bike off the jiffy stand but make sure to leave the stand down. Very Important to leave the stand down. While the bike is balanced off the stand I slide the rest of the jack under the bike and then start pumping it up with my foot. Works great for me. I can do it with one person every time. I have also found that if I let the jack compress completely when lowering the bike I usually don't need to pull the bike off the jiffy to get the jack underneath it. I have the harbor freight yellow jack. t is quite simple once you get used to it.
Old 03-06-2007, 05:25 PM
Kong Kong is offline
Hang Around
My Garage
I generally keep my bike up on the lift. I had one bikestolen out of the garage once and anything I can do to slow them down by even a second or maybe make just a little bit of noise while they try to make off with it is a good thing in my opnion.
My lift is the heavy red steelone from Sears not the yellow aluminum one. I usually rollthe liftunder the bike as far forward as possible with the jiffy stand down, then while sitting on the bike and holding it upright I simply roll the bike forward until the frame and the lift's arms contact and then I hit the foot pedal. My bike is a Deuce and its lowered in the rear - 1.75" at the moment. I don't have any problems at all with the lift fitting under the bike and the lift comes standard with protectors on the arms. Forwhatever its worth the bike balances best when the lift's forward arm is about an inch behind the jiffy stand. With it in that position and the front end strapped down to the lift it is rock solid.
Old 03-06-2007, 05:51 PM
20NightTrain03 20NightTrain03 is offline
My Garage
Quote:
ORIGINAL: anubisss
i also have the same lift and use the exact procedure you described.........
except since my bike is lowered so far down in the rear i roll it up on some wood to get the clearnace i need
__________________
NO BUTT, NO PUTT!
2003 Night Train FXSTBI not stock
1991 chopped 1200 sporty DEFINETLY NOT STOCK!
2008 Street Glide 103 SE big bore looks stock but the motor aint!
Old 03-06-2007, 05:52 PM
SCJE8's Avatar
SCJE8 SCJE8 is offline
My Garage
I have the Sears Craftsman aluminum jack...very nice, very smooth. Depending on what maintenance task I'm doing (need the front end up...need the back end up) determines where I locate the jack under the beast for balancing purposes.
anubisss is right...keep your jiffy stand down at all times! When you are lowering your bike back to the ground and the motorcycle finally lands on both tires it is very easy to have it off-center and the possibility ofthe bikefalling over. That's why it's important to have a good jack with a smooth action. My buddy has an old no-name jack that leaks fluid all over the place and makes my heart skip a beat everytime he's lowering hisscooter...the jack just seems to drop an inch or so at a time! Too damn nerve racking for me! Anyway...don't be a statistic when doing something as simple as jacking your bike up or down!
Good luck!
Steve
__________________
2008 Vivid Black FLHTCU
Pensacola, Florida
Old 03-06-2007, 05:59 PM
mcpastor's Avatar
mcpastor mcpastor is offline
Prospect
My Garage
Quote:
ORIGINAL: OneBlackFly
Yes, get the frame protectors. They are orange semi-hard plastic and cushion the frame to allow the shocks to clear the lift. About $15 and well worth it. See this link: www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=84552444184791 5&FOLDER%3C%3Efolder_id=2534374302289555&A SSORTMENT%3C%3East_id=2534374302289555&bmUID=1 173211320480&bmLocale=en_US
Thanks for the tip. I use a yellow sears aluminum jack. No problem getting it under the bike at all. I am always careful, however, to visually line up the jack pads so they don't contact the shocks. This makes the bike back-heavy on the jack. One option is to tie it down. I've never done this. Another is to just be very careful. This I do. The bike gets really squirrelly though when I clean the back wheel.I'm gonnagit me sum o' dem frame protectors.
I spoke witha friend who never gave his shocks a second thought. He just shoveshis jack under the bike where it balances best and raises it up. I had previously ridden his Softail and the suspension felt very lethargic to me. Hmmm.
And yes... Keep the jiffy stand down...and be careful the bike doesn't start leaning to the opposite side when lowering! I had a very close call and had to use a football block to get it over onto its stand. That's one reason I've found it best to insert the jack on the right side ofmy bike.
__________________
"HE DRIVES LIKE A MADMAN." -- 2 Kings 9:20
Old 03-06-2007, 06:22 PM
Brettsterhog Brettsterhog is offline
Hang Around
My Garage
I have the yellow aluminum jack from Sears as well that I use on my Springer. Have never noticed it lifting up on the shocks- maybe I need to pay more attention, but I think I position it far enough forwad it only hits the frame. Anyway, I position it from the left side of the bike- have never tried the right side- might be better. Everytime I lift it just so the tires are off the ground, then give it a little shake to make sure it's stable. Haven't had any trouble so far. It seems like it would take a lot of shaking to knock it off balance. Thats how I do it anyway.
Old 03-06-2007, 06:41 PM
My Garage
The shocks are lower than the frame tubes, so no matter which jack is used, the frame protectors lift the bike on the frame tubes, not the shocks.
__________________
... Paul ...
Tags
assemble, craftsman, davidson, harley, lift, lowers, sofetail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
