Wrapped pipe pics!!!
Old 08-10-2011, 03:47 PM
BayBones's Avatar
BayBones
BayBones is offline
Default Wrapped pipe pics!!!
Thinking of putting a wrap on my new Cycle Shack pipes on my 09 Cross Bones and am looking for you guys with wraped pipes to post some pics and details about your wrapped pipes, how you did it, are they blackk or white etc.etc.........let the posting begin. (Don't let me down guys!)
Old 08-10-2011, 06:48 PM
Fierofly's Avatar
Fierofly
Fierofly is offline
Bought some Lava (supposed to look like carbon fiber, but looked more olive drab)wrap 50ft x 2" on E-bay. Removed cat convertors and stock exhaust. stuck a pipe in the ground that fit inside the tailpipe. Put exhaust over pipe, put gloves on and started wraping from back to front, overlaping by half as tight as possiable DRY. put a stainless hose clamp on both ends, Did not paint yet and after 700 miles still looks good, so probably won't. Cut stock heat shields and installed where leg goes over pipe.
Old 08-10-2011, 08:07 PM
PureDeath's Avatar
PureDeath
PureDeath is offline
Fierofly............looks good bro, it's goes with bike!
Old 08-11-2011, 03:37 PM
Fierofly's Avatar
Fierofly
Fierofly is offline
Thanks man, something different to do till I get some money for different pipes. Sounds better with the Cats removed also. Should be interesting to see how it holds up. I've heard it causes some pipes to crack.
Old 08-11-2011, 05:17 PM
dansax's Avatar
dansax
dansax is offline
Looks good.
Old 08-11-2011, 05:22 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Not to talk it down, or make you change your mind, but if/when pipe wrap gets wet - it affects the metal underneath. I've seen riders w/rusted-through pipes from wrap so keep this in mind when deciding. Looks good - definitely has after-affect(s)...
Old 08-11-2011, 08:55 PM
05KrazyTrain's Avatar
05KrazyTrain
05KrazyTrain is offline
man, i thought this thread would have had alot more pic posts in it by now
Old 08-12-2011, 12:16 AM
micahpop's Avatar
micahpop
micahpop is offline
I wrapped mine with DEI titanium wrap. Didn't need to wet it and was pretty straightforward with the pipes off.
Old 08-12-2011, 08:04 AM
oct1949's Avatar
oct1949
oct1949 is offline
found these
heres more if U want to look.
http://www.google.com/search?tbm=isc...0l0l0l0l0ll0l0
Old 08-12-2011, 08:10 AM
hspring03's Avatar
hspring03
hspring03 is offline
There are a few other wrapped pipe threads out there already.. Here are my true duals wrapped
Quick Reply: Wrapped pipe pics!!!
