Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Sponsored by: Cajun Shine All
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-30-2009, 07:05 PM
maa148 maa148 is offline
Hang Around
Default simple question about idle on EFI.
Can the harley dealer lower the idle on my softail custom? If they can, will they. I have a feeling that they may get funny when i ask them to do it. I just dont want to hear the crap about things not working right if you lower the idle 100 rpm. Thanks for the help
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-30-2009, 07:07 PM
HarleyGoodies's Avatar
HarleyGoodies HarleyGoodies is online now
Premium Sponsor
It is set to give the top end a proper amount of oil. I doubt the dealer would even do it. If you want a slower lope get some se 203 cams installed. That should take care of it.
__________________
60 DAY MONEY-BACK GUARANTEE - FREE PRIORITY SAME DAY SHIPPING
EXTENDED PROMOTION - GET A FREE SKULL BANDANNA WITH EVERY ITEM ORDERED
Old 10-30-2009, 07:44 PM
Bowtieman31's Avatar
Bowtieman31 Bowtieman31 is offline
Well, the fact of the matter is; you will "hear crap" because its true. As stated above the idle speed needs to be a little higher to keep the upper end, lifters and chain tensioners working properly. Unless your idle speed is exceptionaly high, a dealer won't touch it due to the liability of ruining the engine.
__________________
I don't wanna pickle...I just wanna ride my motorsickle - Arlo
Old 10-30-2009, 09:47 PM
KumaRide's Avatar
KumaRide KumaRide is offline
Curious, is the idle speed for carbed 00-06 bikes also ~1000 rpm?
__________________
Love them FB's.
06 FLSTFI
21's, Cobra HP 2n1, DFO, Spoked Smoothies
http://hdforums.com/forum/members/kumaride-albums.html
Old 10-30-2009, 10:20 PM
harleyheaven harleyheaven is offline
Prospect
Quote:
It can be lowered a little if it's idling really high, maybe 100 rpm or so. Should be around 1000 rpm and not lower than 950 rpm from what I understand. I'm sure others are more knowledgable than me in this area. What is yours idling at now? Other post are correct, it must be at a certain rpm to maitain oiling and voltage. A different cam will make it sound lower.
__________________
2005 Anniversary Edition Fatboy 95" with 104 hp & 102 ft lbs tq, 211 SE Cam, Power Commander, T-Man Stage II Heads, Vance & Hines Big Radius 2 into 2 pipes, Performance Machine Hooligan wheels and mathching air cleaner, assorted list of mods...and always ongoing!
Old 10-30-2009, 10:25 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is offline
Quote:
absoluty 950 the lowest . 1000 preferred. theres a reason oil pressure possibley could drop to an unacceptiable pressure or not enuff volume of oil to top and the oil is what keeps the bike at temperature it could cause unnecessary heat which will cause unnecessary wear.
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Old 10-30-2009, 10:29 PM
RHillbilly RHillbilly is offline
Prospect
put a wooods cam in it for a good idle sound
Old 10-31-2009, 09:14 AM
Hang Around
Quote:
I understand all that. You have experts out there who say that you can't touch the idle and others that say there is a safety factor built in that you can drop the idle 100 or even 150 with no problems. for example i bought a harley lowering kit for my old softail and the dealer said it would only lower it 1 inch. Other manufaturers of the same type kit say it would lower it 2 inches. the dealer finally confessed and said that for leagle reasons they have to tell you that it will only lower it 1 inch. I understand there point of view. I'm starting to look at new ECU's for my 08 FXSTC. I'm just looking for advice before i spend 500 bucks on it. It will take me 2 months to save that kind of cash and i don't want to make a mistake. Thanks again all.
Old 10-31-2009, 09:57 AM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
Prospect
i very low idle is very bad for the lower end,it tends to flatten the roller rod bearings,on a mag morrelli t.body you can lower it yuorself,theres a little torx screw on the lower rh side (next to the a/c mounting bolt) a delphi will need a scanalizer
kirby
Old 10-31-2009, 12:09 PM
zer0t zer0t is offline
Prospect
500 bucks is s-load of money. I'd keep it in my pocket.
__________________
2003 Heritage Classic
JD Cycles 95" Baisley heads Baisley roller rockers Baisley oil pump spring Woods TW6-H cam
10.5:1 compression TTS Master Tune Barnett clutch D&D Fatcat Zippers high flow AC
Uncorrected 110.45 HP & 114.19 TQ
SAE 104.49 HP & 108.03 TQ
Tags
davidson, efi, fuel, harley, idle, injected, low, lower, lowering, master, motorcycle, set, tts, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
