Maybe this is a dumb question, but can you buy the software and computer cable to re-MAP the stock EFI? I would like to do this myself rather than take it to the dealer after i put pipes on my 08 FXSTC. I have looked on the internet and cant find anything for the average person to re-MAP the stock system. I have found all the Power Commander or Thunder Max new systems but why not just use the stock one. Thanks in advance for any help!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
u'll probably loose some low end torque since the engine exhaust is not as restricted with the stock pipes, but from what i've read this shouldn't harm the engine...beaureed445 is right, if u change the a/c the ratio between air and fuel needs to be changed, and this is done by a re-map, or piggy back like power commander, or replace the ecu...the tmax with auto-tune uses wide-band o2 sensors instead of narrow-band like the stock ecu...i think there's a version of power command that also has wide-band sensors...many people use the sert and are happy with it...
this might be helpful: http://en.wikipedia.org/wiki/Oxygen_sensor
__________________
"bad luck wind been blowing at my back"
Yes, it was called the SE Race Tuner (SERT )now its made for HD by another company and I think its called the Pro Tuner , its listed in the ES Catalog. Cmes with a cable and software to allow you access to your ecm as well as some canned MAPS.
I think he was looking for a Cheap way to remap the stock unit. Free stuff, cheap cable. I could be wrong but that doesn't look cheap at all. Our local dealer is running that complete install and dyno for under 600 bucks. You get to keep the Race tuner, but of course no cable or software. Figures!
ditto, but i like thundermax and can even change the speedo setting to calibrate
__________________
2007 Fatboy
Hooker Rebel, Arlen Ness Big Sucker, Mustang seat, RearAlert
Thundermax with autotune, Dunlop RoadSmart 200/50 rear Avon Storm front 130/70 http://gallery.me.com/tk353
