The TTS manual talks about that. It cautions on dropping the idle below 900 rpms. I think mine is set at 984 at running temperature and incrementally higher for cooler temps.
Do you happen to know the stock redline figure? The TTS map I put in is set at 6200 and I'm pretty sure that's higher than stock but not sure.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
On my TC88, the stock filter will flow all the air the engine needs with my SE pipes (baffles drilled out). All I did was cut another opening on the backside of my filter box to match the front one. The bike started stutter when I would slowly accelerate ~ 1/4 throttle. I ended up giving it 1/2 turn on the enrichment screw and she runs like a top again. I'm quite certain that a K&N flows more total CFM than a stock filter, but I think an opened up stock air box with a stock filter will flow more than enough air for a stage 1 on an 88. Probably on a 96" also.
The stock ECM rev limiter is set to 6200 for "B" (Softail) engines. But I reset the limiter on my TMax to 5500.
it just doesn't make any sense to me to flog the engine at rpm's higher than that when it pulls harder if I keep the rpm's below that level.
__________________
07 FXSTC
Thunder Max w/Autotune
V&H Big Radius, ScreamJet intake
U.S. Army Vietnam Vet
FOR THOSE WHO FOUGHT FOR IT - FREEDOM HAS A PRICE THE PROTECTED WILL NEVER KNOW.
True. I've never hit the rev limiter because I can feel the power dropping off before I hit the limit. For me I guess it's there in case I snap a belt. Then the rev limiter would be most appreciated.
I loaded another map (AF176), edited the displacement down to 1584 and took it for a ride. Very nice consistent power but I think my mileage is going to be pretty bad. At least according to the r mileage. Normally after a fill it reads anywhere from 191 - 210 miles. This time it only read 175. That's only 35mpg if it's true.
Temperature today was 86 and after a good 45 minute ride the oil temp was 222. That's a 20 degree drop from what the bike normally runs at. Now that's a considerable drop.
Hopefully mileage will be reasonable and my r reading is a fluke.
