Fat Boy Cut Rear Fender
Well its getting colder and my weekends will be busy of upgrading the garage with some fresh paint paint and a new floor but before i do all that ..... i would like to start look at a another bike project. Has anyone cut there back fender? If so did you send it out ?Or do it yourself? I am pretty handy just have a bunch a of questions before i start making sparks
Will you be lowering the rear too? I would think it would look sort of dorky with the large amount of space between the top of the tire and the fender. I guess I am assuming you will be chopping it up high around 12 o'clock or there abouts.
A buddy of mine did this to a 90 softail and regretted it, ended up buying a new replacement fender.
Did it to an 89 Fatboy
brian2762@hotmail.comI will send you the pics Asap, i cut it into a hounds tooth to match a custom seat i built I also welded and redrilled it to lower it looed good, got alot of love at the shows, fire away with any questions....
As long as you stiffen the preload it will ride fine. With the preload all the way soft ie. stock it will bottom out easily.
